The lower you go in theory the worse the geometry will be compounded further by spacing the k frame down. Presumably there is a point it would get to where it starts to cause a problem (vibrations, grabbing, noise, etc). Shows how capable a cv joint can be for there to be no obvious issues.
Luke, did you use 10mm spacers for the front subframe or did you go more?
Reason i ask is because you say you dropped the subframe 30mm......
If so did you just use longer bolts through the front chassis?
  • 6 months later...
Didnt want to start a new thread but can we hear more about people running the gearbox bolts out ?
Was it okay , or was it worth getting the holes welded and retapped?
Hate the look of it aye, havent got a full tune just yet but yeah.. doesnt look the best and im a lil worried about the torque through it.
It's not ideal but not the end of the world. There's minimal actual "twist" between the engine and gearbox. All of the force runs straight though the shafts, not the box. The only force is created from the friction of the input and output bearings so basically nothing.
There's a huge number of cars that just have a cover plate over the lower half of the gearbox so don't have any bolts holding them to the sump.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
