Harro,
Just stuff lying around the garage, all parts are used.
Factory Steering Rack Ends/Tie Rods $10
Factory Steering Tie Rod Ends $10
Factory SMIC $50
Factory SMIC piping $50
Factory Cross over pipe & BOV $50
Factory Down pipe $20
Factory Dump pipe $20
Factory Catalytic Converter $50
Factory O2 sensor $10
Factory Mint Handbrake OEM boot $10
Factory HICAS unit $20
Factory Passenger side kick panel, 1x flare clip broken $5
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $100
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $30
Blitz 60mm Gauge Holder $5
Subframe Lock Collars - Blue in Colour, full set (8 pieces) $40
Contacts: PM or Reply Here
Location: Canley Vale, NSW, 2166 (AH) OR Milsons Point, NSW, 2061 (BH)
Will post some items, but prefer pick-up. Will give discount on bulk purchases, and yes I accept beer as payment also (no VB, Fosters, XXXX, etc..)
Would you post to sa? If so how much would you want for them sent?
yeah and $20 ontop would cover it
Schizzle for sale... help me fund mah modz :)
Factory SMIC $50
Factory R33 GTS-t Manual Radiator, working removed for upgrade $40
yezzzzz
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Friday bump this schizzle...
You know I'm negotiable right? How about give me 3x slabs of Blonde and you can take everything remaining in this thread.
Sold:
Available:
Factory SMIC $50
Some updates, tyres fell through.
Take everything available here for $150 or 3x slabs of Blonde.
Sold:
Available:
Factory SMIC $50
Factory HICAS unit $10
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $80
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $20
Fully Sick Gearboot & Handbrake Boot in black leather with purple Stitching $10
Sold:
Binned:
Available:
Factory SMIC $50
Hey bud
I'm interested in the dump pipe, down pipe and the bov (if you're willing to seperate it)
Though i'd need it posted to vic.
I'll pm anyways
  • 3 weeks later...
Sold:
Binned:
Available:
Factory SMIC $50
  • 1 month later...
Available:
Factory SMIC $50
Superlow Rear Springs R32/R33/R34 GTS-t/GT-t $40
Sold:
Binned:
Available:
Factory SMIC $50
Factory Blow Off Valve $30
Factory R33 GTS-t Manual Radiator, working removed for upgrade $20
Sold:
Factory Cross over pipe $30
Binned:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
