Available:
Factory SMIC $50
Factory SMIC piping $50
Factory Blow Off Valve $30
Factory Down pipe $20
Factory Dump pipe $20
Factory Mint Handbrake OEM boot $10
Factory HICAS unit $10
Factory Passenger side kick panel, 1x flare clip broken $5
Factory R33 GTS-t Manual Radiator, working removed for upgrade $20
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $20 - pending
Blitz 60mm Gauge Holder $5
Fully Sick Gearboot & Handbrake Boot in black leather with purple Stitching $10
Sold:
Subframe Lock Collars - Blue in Colour, full set (8 pieces) $40
Factory Catalytic Converter $50
Factory O2 sensor $10
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $80
Factory Cross over pipe $30
Superlow Rear Springs R32/R33/R34 GTS-t/GT-t $40
Binned:
Factory Steering Rack Ends/Tie Rods $10
Factory Steering Tie Rod Ends $10
Available:
Factory SMIC $50
Sold:
Binned:
  • 3 weeks later...
Available:
Factory SMIC $50
Factory R33 GTS-t Series 2 ABS Viscous LSD (no sensor, I'm using it) $250
Factory R33 GTS-t Series 2 Stock Turbo with Rubber intake & cast dump $250
Sold:
Binned:
  • 1 month later...
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
