Well for something different I have been on a new anti depressant and various sups for a while now and just failed a work drug test fun fun
LOL from your prescribed medication and legal supps? Surely the failure of the test won't matter then right?
I don't touch the stuff. But getting stood down from work until retest kind of sucks. Had to give them a list of what sups and meds I take.
Balls. Surely when it's cleared up you'll still be paid for the period you were on stand-down?
Your Housemate Troy:-
If he starts things and goes off onto tangents, is bubbly but gets scatty or off with the fairies, always needs company, has loose bowel motions, complains and whinges > quite probably is bipolar.
If he's a loner, broods, interfering, manipulative, opinionated, feisty, defiant and stubborn > probably short on serotonin ie passive/aggressive
He loosely fits into parts of both those categories, lol. It's really hard to tell as he's been dealing with whatever it is for quite a few years, so he's actually really good at just dealing with it. You wouldn't know he had suspected bipolar at all unless someone told you :( But definitely fits more into the bipolar "symptoms" you listed there.
A bit of an update, the mrs grabbed some Swisse Mood pills for me.
Have been taking them for the last month along with some Fish Oil, Swisse Men's Multi, Immune booster and B12 pills.
Have also been gymcercising for the last fortnight and things seem to be getting a little better. Still got a short fuse from time to time but things are appearing to get better. When something big happens, that will be when I know more.
Shall see how this goes and keep you guys posted. Hate going to the GP so haven't ventured that path yet.
Thanks for all your advice.
  • Like 1
haha pretty bloody much hey! He and his partner's cat is actually f**king awesome, it's so close to a puppy it's not funny. Whenever his mood sinks into depression, Stitches (the cat) seems to be able to tell straight away and is immediately REALLY affectionate and loving towards him, which helps heaps. Best cat I've ever met, might as well be a dog lol...I mean it was practically raised like one :D
Fuark! That sucks mate!
Can you get a doctor's certificate to prove that you haven't been taking anything illicit? That may assist your cause and help you get back on sooner.
Yeah apparently. Just got called back in. Apparently I can drive normal vehicles but not trucks...... Can't do high risk activities even though my job consists of nothing but high risk activities playing with electricity
Only had to state meds afterwoulds and also spoke to the work doctor who said current meds and sups would not cause a non negative result. After woulds I than tried a in house test and it failed to read thc ( not failed not passed ) I than tied another one which passed. It's been a slow slow day
Edited by Kenna802
A workmate failed his because he ate a poppyseed muffin 2 days prior. If you can delcare, they let you stay at work provided it isn't illegal. He couldnt work it out until a doctor mentioned poppyseeds. He had a 5 day holiday.
The fun continues . Had to drive to Brisbane yesterday there and back , all up 6 hours travel in a work car. I would hate to think if there are people that fail the test that are smokers who they give the benefit of the doubt and make them do that.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
