Hi guys, I've been planning on a 30/26. The 26 I have has factory bottom end and worked head making about 500hp with all the bolt on to do so.
I've been out on the track with it a couple of times and had no problems.
Motor and box are out at the moment to put a extended sump and oil head drain.
Bought the car being told the bottom end was fully built. When we took the sump off we discovered it is stock....
So do I just put the 26 back in or do I go a forged rb30/26? The car will be 90% track. Cheers
https://www.sau.com.au/forums/topic/433110-to-3026-or-keep-the-26/
If you're going to do it I wouldn't personally bother with a stock bottom end. Too low in comp. IF you're using it for track you'll want more comp to give you more stick out of the corners. Fine if you're using it for the strip as you can pump in more boostage.
Mate 370kws at the wheels is nothing to laugh at. If it's making good reliable power with good response as it is I'd leave it. One of the reasons I went 30/26 was to make the jump from low 300's to low 400's. For you the jump isn't as big (unless you have a fair crack at it) so that may help in the decision to stay with what you've got.
Put half of the money in to your current setup as a (proper) RB30 build will cost you and you've got a pretty amazing engine.
I'm with Shoota77
Measure your bores and if they are within tolerances put your engine back together with rings and bearings if necessary (or if you're keen a set of forged pistons and a balance) and it will probably go for years. I have an RB30 with a stock bottom end in my Stagea and it is heaps better than the original RB25 and really torquey but its not making 370awkw. You would want a fully forged and balanced RB30 to see a significant improvement on your RB26 and probably end up spending a minimum $10k or easily double that depending on how carried away you get. Your current setup sounds pretty good and you could fairly easily get a few more KW if you really want.
Hmmmm yeh. It is responsive as is. I just wonder how much more it can be with the 30 bottom. Sorry guys, this suggestion of keeping my existing engine has has thrown a spanner in the works and confused me.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
