Hi guys, I've been planning on a 30/26. The 26 I have has factory bottom end and worked head making about 500hp with all the bolt on to do so.
I've been out on the track with it a couple of times and had no problems.
Motor and box are out at the moment to put a extended sump and oil head drain.
Bought the car being told the bottom end was fully built. When we took the sump off we discovered it is stock....
So do I just put the 26 back in or do I go a forged rb30/26? The car will be 90% track. Cheers
https://www.sau.com.au/forums/topic/433110-to-3026-or-keep-the-26/
If you're going to do it I wouldn't personally bother with a stock bottom end. Too low in comp. IF you're using it for track you'll want more comp to give you more stick out of the corners. Fine if you're using it for the strip as you can pump in more boostage.
Mate 370kws at the wheels is nothing to laugh at. If it's making good reliable power with good response as it is I'd leave it. One of the reasons I went 30/26 was to make the jump from low 300's to low 400's. For you the jump isn't as big (unless you have a fair crack at it) so that may help in the decision to stay with what you've got.
Put half of the money in to your current setup as a (proper) RB30 build will cost you and you've got a pretty amazing engine.
I'm with Shoota77
Measure your bores and if they are within tolerances put your engine back together with rings and bearings if necessary (or if you're keen a set of forged pistons and a balance) and it will probably go for years. I have an RB30 with a stock bottom end in my Stagea and it is heaps better than the original RB25 and really torquey but its not making 370awkw. You would want a fully forged and balanced RB30 to see a significant improvement on your RB26 and probably end up spending a minimum $10k or easily double that depending on how carried away you get. Your current setup sounds pretty good and you could fairly easily get a few more KW if you really want.
Hmmmm yeh. It is responsive as is. I just wonder how much more it can be with the 30 bottom. Sorry guys, this suggestion of keeping my existing engine has has thrown a spanner in the works and confused me.
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
