Horsepower sells cars, torque wins races!
Better tell that to the F1 manufactures...
Actually tell that to any race team that runs a turbo car that smashes larger displacement higher torque V8s. Do you remember Group A?
Or maybe you should grab a 6L turbo diesel and take it to the track and you will obliterate everything!
I personally love that phrase, makes it easy to pick out people with no clue
Edited by SimonR32
Lets compare apples here.
take for eg the current tube frame v8 supercars.
you have a choice, a 600hp SR20 or a 600hp 5L V8
but both still have a minimum weight of 1250kgs, same suspension same tyre etc.
which would you choose?
A SR20 as it would have more torque in the used rev range.
  • Like 1
And it would be geared so it would be in its sweet spot all the time, it would rev faster through its peak efficiency range and deliver torque to the wheels at a faster rate. therefor be much faster overall
Give me a rota spinning to 15000 rpm please
Edited by XGTRX
SR20, because it sounds better :ninja:
RB30 = Better rod stroke ratio.
RB26 = less registration issues here in VIC.
It it was without a custom crank id be going 30, if it was Regoed in VIC id be going 26.
There are lots of arguments for and against it, just as many for gear ratios, turbos etc which would make more changes at improving or ruining each engine sizes characteristics.
You need to look at it as a package, not just a engine package but including weight, gearing, tyres, track etc.
People like Berry successfully running a time attack RB30, lots of others running RB26's, some with stock cranks, some with strokers.
have seen what the Americans are doing with Diesel engines these days or have been living under a rock?
I'm starting to feel like I am wasting too much time on forums, but I had already thrown this together to ponder it visibly so I thought I'd throw this into the mix given that piston speeds/acceleration relative to rod length and stroke seems to come up in these conversations all the time - my maths may or may not be right here (looks close to legit to me haha) but this is more just to get an indicator of the sheer acceleration of the piston (at the pin) of the different factory RB layouts.
I have used this calculation to work out piston acceleration relative to crank angle (l = rod length, r = crank radius, A = crank angle, 0deg crank angle = TDC):
Piston acceleration to sustain equivalent rpm:
Piston acceleration to move equivalent swept volume:
I did it for my own interest so I figured I may as well share it as I know that some other people like to ponder on this kind of thing too. If anyone have a better (or more OCD) handle on physics/maths then feel free to correct or add to it - but again I will probably make myself relative scarce after this so I'm adding it before I lose the bits and pieces I put together.
Cheers.
Sound... I'll just leave this here:
K'n hell. How many million revs is that thing pulling as it crosses the line? Sounds awesome.
Edited by Cowboy1600
Le Mans :P
Where they are quite a bit slower than the other cars but way more fuel efficient so don't have to stop as often.
It's not the torque which makes them competitive.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
