That's fine, but for the average joe blow on a "normal budget", why would you want to rev the thing past 8000 RPM.
But isnt that the point. The original poster is talking about shoudl he throw a 30 bottm end in his car. He hasnt talked about changing cams, turbos etc...so he is simply moving his power brand down 500-700rpm. he is talking about track days, not competition and just wants to do them reliably. You then talk about people with a normal budget...well a built 26 bottom end needs pistons and bearings, std crank and rods can do the job for a gob of power. If its an R32 sometimes there are bonnet clearance issues etc.
An RB30 bottm end is going to most likely needs rods as well as pistons...need sump adaptor, more machine work for the head studs,. mod dump and cooler pipes....If you want to spend the extra cash and have the extra headroom for future power mods with bigger turbos etc..But the tone of the original post suggests to me best stick with the 2.6L. He said it was responsive as is. HBut he also said budget isnt a concern sooo... present both side of the discussion
You dont need to.who said you did. but it would get there at the same time a 30 will get to 6500. 26s spin up a lot faster because of the shorter stroke thats my point
Does that mean an RB28 will get to approx 7300 RPM by the time the 26 gets to 8000 RPM?
^^ ur a funny guy!! By this logic roy has us all beat with his rb20.
All this time I thought it had to do with turbos blade tech and flow mechanics with proper headwork and correct cam choice.. f**k ive wasted my time and money
brb going to destroke my engine real quick
  • Like 1
Your right. Roy is on the money. I bet a well set up rb20 would tear strips off a garden variety 26 or 26/30.
Takes a lot more than capacity to be a good track engine....
Plus it would sound better too
Whipper snipper? 26 cc of fury!
That will push a heavy GTR around the track like a bulldog!
  • Like 1
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
