To 30/26 Or Keep The 26?
SIR-JD
 Share
I like where you are going there Mick, serious potential for you there - you could use RB26 pistons and short rods (so it will sound awesome) to make a 1.7litre... put a T66 on it with a 2" exhaust and get 50psi by 3000rpm. Will be tough!
  • Like 1
BAAAAAAHAHAHAHA! :D Just wondering if the T66 might surge making 50psi @ 3000? Maybe I should put a bigger exhaust on to increase lag say something silly like a 3.5" system and bring the turbo on around 1000rpm later? ;)
Lol as long as your car "sounds fast" the chequered flags yours!
I am never going to race so i give no farks about about chequered flags. Re some good tunes every time I drive the car...well I would take this sound any day I drove my car...who cares if its slow
https://www.youtube.com/watch?v=FzvMQdxUPsM
https://www.youtube.com/watch?feature=player_detailpage&v=V667PHZwaYI#t=815
Ask Gerg_31 (I think that's his name) I would bet that whilst his non turbo'd, open throttle bodied RB26 engines he was playing with would have made only average power, they would sound much like the amazing Hakosuka with the right exhaust. Turbo's are an unfortunate muffler of raw engine sound. They take the individual pulsations out to a large degree.
There is some merit to the "sounds better goes better" ideology. I put an exhaust on my VL when I was 19, probably made zero more power but f#$k I felt fast! I'll trade in my noise for power anyday however. Show with no go only tingles in your balls for so long....
Now thats what i am talking about. what a sound, sheer perfection
This is why I love my slow alfa so much.
https://www.youtube.com/watch?v=2YIRhzKDamg
Edited by XGTRX
500-1000awkw
that's also a huge range! It really comes down to what engine characteristics you are chasing. for a street car more torque pretty much always makes a quicker nicer to drive car. I know I rather a 300kw rb2530 than rb25 due to the far improved driveability. ( and that's why I went for a 30 bottom end) Edited by superben
What i was trying to say is that id rather keep the 26 and spend the cash on other areas of the car. Id be quiet happy with 300-400kw on a 26. Then again some might not comes down to personal choice i guess. I wouldnt change the 26 if i was going with twins or a average to decent sized single.
I'm with superben. Displacement adds drivability.
Having said that I have sacrificed some low end torque with my new setup for the sake of having a nice sound to listen to, and gone for some big cams and a massively high flowing exhaust.
I think many of you focus too much on which rod ratio is better and are afraid to go much shorter than stock. In small piston engines like the RB's it doesn't really make a lot of difference with reliability/longevity of the motor. Its not as though the engine is throwing around 4" bore pistons. The SR23 engines with 137/91 = 1.5, with a 89mm more is a good example.
There are advantages for the short rod ratio engine in a street car too. The main one that comes to mind is that a radically ported head will work well at lower engine speeds, due to increased piston speeds and higher vacuum pull. This is part of the reason Piggaz's combination works so well.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
