Again put up some lap times that indisputably show it's worth the change.
All I have heard is opinions on how much faster the 26/30 SHOULD be around a track....I have looked myself and can't find any, so until I find data that there are SIGNIFICANT advantages to change a 26 to a 26/30 on a daily that sees 12 track days a year then as far as I am concerned it's not worth it...and if well setup will continue to be a force on the track.
As for the 34 on -7s I remember it had cams in it and produced more power than the 32 you have...I think it's you....from what I know you just moved the sweet spot up by 800rpm...not the best setup for circuit as the -7 would quickly run out of puff and torque would come on too late to take advantage of their lower rpm efficiency.
And yes I know of many people using 26s and running 8-9 sec quarters. A guy in qld had the fastest 26 running 7.5 from memory. And yes there is word that the mattouks like others are using patrol blocks to run more boost, so not true rb 30s
As for everything else...well lets just agree that we disagree on what we think is a better car to drive on the street and many people that I let drive it love it and rave about the performance and characteristics of the 26 and yes these are people with vls, ss, supras, 200s street cars that many run 9-10 secs quarters and know how to throw a car around a track.
No disrespect to you or your opinions but I have driven and been in many 30s and 26/30s....great engines....but if I wanted all torque down low I would drive my v8 but I don't and I love driving a 26 that is very comfortable driving around under boost in peak hour and is very rewarding at 4000+rpm when I want to play.
But each to their own...all good.
yeah ok what ever guy, I'll just correct you on what you think you know about my cars, it was -7s on my 34 with cams injectors etc etc and yeah it made more power then my 32 but yet ran an 11.8 against 11.1 for the 32 so that proves power isn't everything, the 800rpm increase was a change of cams not bottom end and it was the car came on boost 800rpm sooner, was easier to drive/more powerful off boost and was still holding 20 psi at 8000 and with a leaking rear manifold to turbo gasket and shite tyres, stock brakes and suspension I still managed 1.09 around wakefield
as for the 30 swap there isn't a result for that yet as it hasn't been tuned, I've only just finished the supporting mods for it and it doesn't get tuned till the end of next week, then we will see the advantage of a 30
OP asked for opinions so heres mine, if your 2.6 isn't broke use it, if it does stroke it
Oh I remember you now, your the guy that posts alot of shit without any evidence you even own a GTR except your user name
I think there's lots of oxygen in the old can't beat cubic inches argument though forced induction changes the playing field significantly . yes and no, tech changes that field, look at the little honda motors, that said put the same tech and boost at a bigger displacement and it will always be better
I'd say that saying came from the states in decades gone by where fuel was cheap and big V8s were everywhere .
My take is that more cubes makes everything easier because you need less revs to achieve the same thing and the increase in low rev part throttle torque is often directly proportional to the capacity increase . We know full well why Nissan went with 2568cc and it had nothing to do with making a GTR a nice all round road car .
I don't know for sure but I think the RB25 and 26 blocks are externally the same dimensions as the RB20 that they'd had for a while before the GTR saw the light of day . I don't think either 25 or 26 are exactly ideal bottom ends and the blocks could have been taller and their rods longer . From this perspective the RB30 is better because the bore stroke and rod stroke ratios are better , the 26 combination is the least desirable IMO and stroking their std height block makes the situation worse again . This is not to say those combinations don't work its just that they're not exactly ideal .
Look at the apps RB30s went into and its hard to deny they wanted more torque in a lower state of tune - read cheaper to manufacture and sell single cam types . I think Japan and NZ had SOHC RB20s and we got SOHC 30s in R31s/VLs and ST Patrols . VLTS had 30ETs in a really soft state of tune and getting the 155 odd crank wasps up to 209 would have been a walk in the park with a half decent IC CR increase and something a bit better than a small series Garrett T3 .
A 3L factory R32 GTR making the same 209 kw should have had more linear power delivery than 2568cc versions and I think would have pleased more people who bought them . Not everybody gets off on reach for the sky rev counters and boost gauges and a road car that "feels" peaky takes more effort to drive if you want it to pull well everywhere .
Gearboxes , they are a problem in road cars given a big bootfull of revs because strong enough shafts gears and syncro hubs have a lot of inertia and convincing everything to slow down at change time can be difficult . I knew a feller that tried dragging a VLT with an RB26 and the std wide ratio VLT box and it would never change gears properly . If you don't want to go to dog boxes closer ratios and more torque at less revs is an advantage .
Anyway I agree with Lithium in that reducing the state of tune (boost) is the way to torque limit a larger engine , this doesn't alter the RB30s ability to out muscle an RB26 at 1-3000 revs and pull higher gears down there .
Ultimately high revs is where wear and tear are so if you can in theory make the same power at less revs then the engine should have a longer useful life between rebuilds if serviced properly and not abused . Better fuel consumption from not having to boot it everywhere is a bonus . Some of you may laugh at fuel consumption woes but try driving that hotted up GTR everywhere and living with the fuel bills . I think the consumption killer is having to dump extra fuel in every time the engine goes into boost , if it made adequate part throttle torque and the turbos were sized not to spool every time you breathed on the go pedal it's easier to get acceptable consumption .
Anyhow blame the Grp A regs and the weight class Nissan wanted to race the GTR in .
A .
I remember watching or reading some thing about the making of the R32 GTR and from what I remember it was going to have a RB25 but when they finished the car it was to heavy to be competitive in that class so they inceased the stroke and lifted the piston pin hieght to increased the engine capacity by 70cc over 2.5ltrs, everthing else you've said is exactly why I built a 30 :thumbsup:
It comes as no surprise manufacturers use displacement when they want to improve engine performance from one model series to the next. The only exceptions are when a manufacturer opts for forced induction over a previous naturally aspirated engine, and even then in time they may increase the capacity of the forced induction unit later in the model cycle.
Mazda: SP20 2L- SP23 2.3L - SP25 2.5L
Subaru: 2L - 2.5L
Nissan: RB20DET - RB25DET / CA18DET - SR20DET / RB26DETT - VR38DETT
GM/GMH: 5.7L - 6.0 - 6.2 etc.
Ferrari: 348 - 355 - 360 - 430 - 458
Porsche 911: 2L - 2.2 - 2.4 - 2.7 - 3.0 - 3.2 - 3.6 - 3.8 - 4.0
Regardless of the engine, forced induction or naturally aspirated, there really is no replacement for displacement.
RB30 without a doubt is a better base to start off with if you want a power house. Like i said before i wouldnt swap the RB26 for a 30 if my gt-r was going to be a mildly modified daily. Ive stroked my 26 to a 28 due to going big single otherwise i would had stayed with the 26 if i were going to keep the twins.
All the money you would need to spend on a 26/30 could be spent on other areas of the car likes brakes/wheels/suspension etc.
Edited by Tyranus
So you're agreeing that you putting cams on a -7 setup made your car slower and a pig to drive.....funny people have been reporting this for 10+ years and there are results to support this NOT a favourable setup.
Yeah you're right I don't own a GTR and all my experiences are pretend fantasy world delusions. Grow up mate. Don't try to discredit me because we have a difference of opinion.
So, putting cams in a basic setup like the one mentioned above is a bad idea because it may push the curve to the right a tad, but putting a bigger engine in the car which will push the curve to the left is also bad?
just to summarize...
putting in a RB30 requires more supporting mods..meaning u cant just use those existing on ur RB26 else it'll perform worse?
so...maybe to some, it boils down to cost effectiveness and/or purpose. no right or wrong... as long as it fulfils ur requirements and wallets.
chill guys :)
Because Internet argument.
Subaru: 2L - 2.5L
Yeah and then you turn up to one of their track days with a GTR with a 300kw 26 and decimate them all....as has happened many times before. And the thing that's amazing is that after 20 years a lightly tuned well sorted GTR can be driven to a track compete with current supercars and drive home. Or that a highly tuned 26 can stand toe to toe with 7 litre turbo charged LSX in a straight line. 26 must be substandard then.
  • Like 1
No it's great but doesn't mean it's vastly superior to a well sorted car with less cubes. That's my point.
Its like having a cam that comes in at 4000rpm on an na ls and having a 2000rpm converter, it would be a slug but put a 4000rpm converter in it and it's very efficient.
some dudes need to learn to read, IT CAME ON BOOST 800RPM SOONER with 250s then it did with 260s, so how does the better response make it slower, it wasn't it was faster, my 32 is just very well sorted given it is basically stock, the 34 hadn't quite got there and I didn't get to drag it on that setup before spinning a big end and bending a crank which is why it now has a 30
the wrong cams will make your car worse the right cams will make your car better, you just gotta know what your doing and not just copy what some dude on the computer did, instead look at what people have done and see what happened and decide for your self what works
I don't need to discredit you, your doing a good job of showing what you don't know all by your self, but it is you that keeps asking for evidence and I haven't seen any thing about anything from you yet, just alot of typing
I'll take it the supporting mods comment was at me and will respond with, no not cause of the 30 but cause I want to see 450+awkw, limited by turbos, the car happily drove around for 6 months with all the old supporting mods but they won't like the power goal and so when the new computer got here they got upgraded to help assist my goal
my stand is this, take two cars one 26 and one 30, same car same mods same setup same tune same same, the 30 is always going to be nicer to drive and faster to race
RB08dett, lol for sure, my 1ltr ninja revs to 13,000rpm maybe I should put that in my car
thanks for clarifying :)
cost wise.. how much was it to build the RB30?
just the engine to fit a GTR ?,
I went for the best of most every thing so my cost was higher then most but I knew what I wanted to end up with, and for the average build not needed
running RB30 $100
forged pistons and rods $ 2000 landed
preping the crank $500
adapter plate including required machining just shy of $3000, I used the Platinum Racing one because it bolts to the girdle as well as the block, I've seen normal steel ones for around $800 no machining required
Nitto oil pump and N1 water pump $1500
machining for over size pistons and bottom end assembly $1500
then say $1000 for miscellaneous like gaskets oil water feeds for turbos, oil restrictors bearings etc
I made 8mm spacers for the subframe and cause I have the long CES dump pipes they didn't have to be modified
really the only thing different to building the 30 instead of the 26 is the adapter plate, every thing else is much of a muchness and once its in and setup rebuilding a broken one is the same as a 26 except replacing the crank and/or block, complete running motor $100-$300
In total for my whole build, hahaha more then I care to tell my wife :whistling:
My adapter plate is the dearest one there is and when I brought it I didn't know the amount of machining involved, $1250 for adapter kit, $1700 for machining
the girdle had 5thuo taking off it then torqued down
then they had to machine the top of the girdle at a set distance from the block
then drill and tap a dozen bolt holes in the girdle for the adapter to bolt to
then line bore
then drill and tap the holes in the bolt for bigger bolts in the block
none of which is required with normal steel one like sky30 uses, they bolt straight up with no machining
$450 is cheap the best I found was around $800 for a kit with all the bolts needed, where did you get it from
the one I have
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=67_88&products_id=1338&zenid=q99cn7eg0qtdsbad43tq8jbvk0
the normal one
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=67_88&products_id=1369
I dont know how quickly the guy plans on upgrading the turbo, but a customs from Unigroup, also a member on here, is planning to upgrade his T04Z to a 6766. It sounds like he will be running the same turbo as ours only it will be a 26 versus a dirty 30 with a 25 head.
Hopefully he does it some time soon so i will see if i can get a dyno graph of the 2 cars to compare the difference in power and torque ;)
  • Like 1
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
