Horsepower sells cars, torque wins races!
Better tell that to the F1 manufactures...
Actually tell that to any race team that runs a turbo car that smashes larger displacement higher torque V8s. Do you remember Group A?
Or maybe you should grab a 6L turbo diesel and take it to the track and you will obliterate everything!
I personally love that phrase, makes it easy to pick out people with no clue
Edited by SimonR32
Lets compare apples here.
take for eg the current tube frame v8 supercars.
you have a choice, a 600hp SR20 or a 600hp 5L V8
but both still have a minimum weight of 1250kgs, same suspension same tyre etc.
which would you choose?
A SR20 as it would have more torque in the used rev range.
  • Like 1
And it would be geared so it would be in its sweet spot all the time, it would rev faster through its peak efficiency range and deliver torque to the wheels at a faster rate. therefor be much faster overall
Give me a rota spinning to 15000 rpm please
Edited by XGTRX
SR20, because it sounds better :ninja:
RB30 = Better rod stroke ratio.
RB26 = less registration issues here in VIC.
It it was without a custom crank id be going 30, if it was Regoed in VIC id be going 26.
There are lots of arguments for and against it, just as many for gear ratios, turbos etc which would make more changes at improving or ruining each engine sizes characteristics.
You need to look at it as a package, not just a engine package but including weight, gearing, tyres, track etc.
People like Berry successfully running a time attack RB30, lots of others running RB26's, some with stock cranks, some with strokers.
have seen what the Americans are doing with Diesel engines these days or have been living under a rock?
I'm starting to feel like I am wasting too much time on forums, but I had already thrown this together to ponder it visibly so I thought I'd throw this into the mix given that piston speeds/acceleration relative to rod length and stroke seems to come up in these conversations all the time - my maths may or may not be right here (looks close to legit to me haha) but this is more just to get an indicator of the sheer acceleration of the piston (at the pin) of the different factory RB layouts.
I have used this calculation to work out piston acceleration relative to crank angle (l = rod length, r = crank radius, A = crank angle, 0deg crank angle = TDC):
Piston acceleration to sustain equivalent rpm:
Piston acceleration to move equivalent swept volume:
I did it for my own interest so I figured I may as well share it as I know that some other people like to ponder on this kind of thing too. If anyone have a better (or more OCD) handle on physics/maths then feel free to correct or add to it - but again I will probably make myself relative scarce after this so I'm adding it before I lose the bits and pieces I put together.
Cheers.
Sound... I'll just leave this here:
K'n hell. How many million revs is that thing pulling as it crosses the line? Sounds awesome.
Edited by Cowboy1600
Le Mans :P
Where they are quite a bit slower than the other cars but way more fuel efficient so don't have to stop as often.
It's not the torque which makes them competitive.
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
