Close! it's 6,000 because you can't rev an rb30 beyond that no matter you do with them
all things being equal, you can always rev a motor with a shorter stroke more no matter how you build them.
That rb 30 z is a drag car, would be totally useless around a track and irrelevant to the ops aim. To get any torque or power out of that thing it would have to be revving at 5000rpm and have nos to get it on boost just to get it off the line.
That's fine, but for the average joe blow on a "normal budget", why would you want to rev the thing past 8000 RPM.
You dont need to.who said you did. but it would get there at the same time a 30 will get to 6500. 26s spin up a lot faster because of the shorter stroke thats my point
So if you have a rolling run from say 4500 RPM in 4th, both engines make the same peak power but the RB30 has more torque through the mid range will still accelerate the car slower than the "rev happy" RB 26?
4500rpm in 4th is same speed as you would be changing from 2nd to 3rd in a RB26 :pirate:
In neutral maybe.
Not when a torquier engine is pushing 1500kgs.
Rb30 would kill it of course with the extra torque, but put both in there sweet spot the 26 cover a greater rev range in the same time if you had identical power and torque figures, which of course you dont. be interested to see this on a graph though.
If you think torque isn't important go back to the graphs and look at the torque readings when a turbo engine comes on boost . Homologation specials like GTRs are not IMO a great example of what production turbo engines/cars are like - because its reason for being was a narrow focus special . Typical production road cars make more torque (same engine/capacity) in turbo form than the NA versions do and surprisingly , for some , at lower revs than the NA ones often do .
Gootta run trains to move , cheers A .
  • Like 1
And who is saying torque is not important.....geez
I am going to take my 70 kw alfa33 out for a trashing now just to prove to myself that...don't know but I am taking it out anyway....I know carbies are better than FI. Hopefully I can find a vl.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
