Yes! I can confirm that is Jeremy.
f**kin' Smash him man! :rofl:
The above claim may be untrue.
Kasko will know about the 33 / 34 suspension but I get the impression they do not fit as he is going to sell the coilovers on his 33 when he buys a 34...
Fronts look the same as someone has said.
But backs are different.
Haven't looked 100% into it though
R34 and R33 front suspension are same but the rears are different the bottom end one will not fit as it has a different type of fitting.
I have a stock R33 suspension and a rear coilovers has this screw type of fitting at the end which can be changed to make it fit r33 or r34 if you want to borrow them let me know.
Dunlop Skyline Boyeeez !!! :D
So far i know there is: 7 skylines in our area, and 2 in charnwood
Black R33 (mine)
Black R33 4 door (not a pulsar)
White R33 with black wheels (charnwood)
Blue R33 Non turbo
Red R34 (RosieR34)
Silver R34 my brothers
Silver R34 GTR (charnwood)
Blue R34 GTR
Black R35 GTR
Black R33 (mine)
Blue R33 Non turbo
Red R34 (RosieR34)
Blue R34 GTR
Black R35 GTR
Blue R32 GTR
All dem cars above are all in a space of like 2KM's of each other. Crazy
Edited by RosieR34
Cheers man, I think I might just get new suspension overall
Blue R32 GTR
Saw that R32 GTR with no number plate a female driver
No worries :)
Black R33 (mine)
Blue R33 Non turbo
Red R34 (RosieR34)
Blue R34 GTR
Black R35 GTR
My white R32 GTR in Flynn
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
