Hey,
I have a set of R34 GTT RIMS 17 inch don't know the rest of the specs they have been powder coated gold but there is a lot of gutter rash will need to be re coated. Has on two rims maxxis tyres almost at the tread market and two with sumitomo with 50+% all are 235/45 need them gone ASAP lookiing for $200ono.
Contact 0430588159 and I can send pics.
Thanks
Dion
https://www.sau.com.au/forums/topic/433193-r34-gtt-stock-rims-17inch/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
