Rb25Det S1 Head Onto N/a Neo Bottom End
HGHOON
 Share
hey, ive done some researching and can only really find people putting neo and s1-s2 heads on rb30- 25det bottom ends etc but havent found any info on puttin an s1 -s2 rb25 turbo head on a r34 neo natro asp bottom end, now people have said that cross matching the turbo blocks with the neo heads will create low compression ratios but if my rb25de neo has a CR of 10:1 it shouldnt drop the comp that much and thus having a nice CR and the strength of the neo bottom ends? also wanna know if the different piston design in the neo will interfere with the head/valves at all?
any info much appreciated
cheers dave
the neo has approx 10cc smaller chamber. find an online comp calculator and figure it out. At a wild gyes I would say you would get around 9:1 but it definitely seems pointless , can you explain what you plan to achieve with the engine?
sorry i didnt mention that i was turboing it, all my manifolds etc wont fit the neo na head(having smaller ports etc), i have the greddy style inlet and everything on an 25/30 in another car but have a gtr head for that now and wanna use the whole 25setup on this r34 gt4, cant just slip the 25/30 in cause of 4wd and would need adapter plates etc. im just tryin to use wat i have in the shed and wanted to make sure it was going to be all good before i rip both cars apart,
yeah i saw a stag neo det and manual box for like 1800 or something like that on ebay was cheap but i dont have that money to spend at the moment and have all this shit to use anyway, i'm not to concerned about the n/a bottom end it should be up to the task, they getting 500hp on stock bottom end neo det and de's use same gtr rods and pistons are a little thicker on top and made of same shit as turbo pistons, just hoping the CR is round 9:1 that way it should in theory be very close to det spec
yeah i dont think the squirters are gunna be an issue as im not going for all out power but having a thicker crown on the n/a piston would be more prone the heat soak but again shouldnt be a real issue on mild power figures i'll have a crack at it!
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
