Rb25Det S1 Head Onto N/a Neo Bottom End
HGHOON
 Share
hey, ive done some researching and can only really find people putting neo and s1-s2 heads on rb30- 25det bottom ends etc but havent found any info on puttin an s1 -s2 rb25 turbo head on a r34 neo natro asp bottom end, now people have said that cross matching the turbo blocks with the neo heads will create low compression ratios but if my rb25de neo has a CR of 10:1 it shouldnt drop the comp that much and thus having a nice CR and the strength of the neo bottom ends? also wanna know if the different piston design in the neo will interfere with the head/valves at all?
any info much appreciated
cheers dave
the neo has approx 10cc smaller chamber. find an online comp calculator and figure it out. At a wild gyes I would say you would get around 9:1 but it definitely seems pointless , can you explain what you plan to achieve with the engine?
sorry i didnt mention that i was turboing it, all my manifolds etc wont fit the neo na head(having smaller ports etc), i have the greddy style inlet and everything on an 25/30 in another car but have a gtr head for that now and wanna use the whole 25setup on this r34 gt4, cant just slip the 25/30 in cause of 4wd and would need adapter plates etc. im just tryin to use wat i have in the shed and wanted to make sure it was going to be all good before i rip both cars apart,
yeah i saw a stag neo det and manual box for like 1800 or something like that on ebay was cheap but i dont have that money to spend at the moment and have all this shit to use anyway, i'm not to concerned about the n/a bottom end it should be up to the task, they getting 500hp on stock bottom end neo det and de's use same gtr rods and pistons are a little thicker on top and made of same shit as turbo pistons, just hoping the CR is round 9:1 that way it should in theory be very close to det spec
yeah i dont think the squirters are gunna be an issue as im not going for all out power but having a thicker crown on the n/a piston would be more prone the heat soak but again shouldnt be a real issue on mild power figures i'll have a crack at it!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
