Hi guys,
When I have the air con on and stop at a set of lights, the idle fluctuates from 500rpm to 750 and continues to cycle like this until I get going. If I clutch in and let the idle dip, sometimes it stalls.
The car's tuned on a Haltech platinum pro and everything's stock besides exhaust.
What could be causing this and how can I fix it? Should I adjust the idle abit higher?
Normal idle is 750rpm.
Cheers
Does the car run absolutely fine with the AC off? If so then there is a chance the car was not tuned to compensate for the AC being on. I know the Apexi PFC has an autolearn feature to set this up for you and control the engine when the AC is on or off, not sure how it goes with the Haltech but the same principle should apply.
As long as the car runs fine with the AC off, I'd be looking at the tune since the compressor will throw out the load tables and could affect your idle.
that is my R33 doing it cleaned my AC valve and it hasnt done it to that extent since.
Maybe give that a clean see how you go it fills up with crap over the years might help there is a DIY cleaning post on here If i CBF id link it but yer just search bro and you will find it.
I had this same problem on my 33. Once with the powerfc and then the same with a Link ecu. Problem was the tune. All that needed to be done was the idle had to be slightly raised through the ecu. Problem fixed and never stalled again.
  • 3 months later...
partially correct, however there are 2x idle settings for the PowerFC.. 1x is idle without AC and 1x is idle with AC on
many tuners somehow always forget to set this correctly, especially when cars run aftermarket cams and you often see them stall at lights.
  • 9 months later...
Hey, ive got the same issue. The revs do not fluctuate as much but the car is rough while standing still. It doesnt stall as I have done the cleaning of the AAC valve. This only happens when the air-con is on.
What ECU?
perhaps your idle valve is set too low, try this...
unplug your TPS connector
unplug your idle valve connector
then adjust the screw till your car is at 800rpm
then reconnect everything and see if the idle is stable with the AC on...
if that doesn't work, unplug the stock O2 sensor and see if that stops it, if so.. your stock O2 is dead
Ok I will try these methods tomorrow morning. It might be something to do with the idle valve as it was idling very high when I did the cleaning and I had to really tighten the screw. Even now, it idles at just under 1000. Not sure about how to get it lower.
Also was thinking of changing the O2 sensor but was unable to get it out so will have to go and buy a removal tool and sensor if I need to change that.....
EDIT: Spelling errors...
Edited by shubby0901
So just to confirm, thats the top or bottom plug on the throttle body? Also is it both plugs for the idle valve?
As for the gasket, I tried to be really careful about the gasket as many people said you can reuse it. I removed it, cleaned with with a dry cloth and reinstalled as it looked like it was in pretty good condition.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
