Hadouken Posted November 26, 2014 Share Posted November 26, 2014 Don't be scared to use it Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432746 Share on other sites More sharing options...
shubby0901 Posted November 26, 2014 Share Posted November 26, 2014 Don't be scared to use it Ive mentioned before that I had already done the cleaning but am still having the issue therefore I asked in a thread with someone else with the same issue. Infact, I used that very article as a guide. The second question was which plug was for the TPS, since that article has only 1 plug where as my R33 has 2. Thanks for the contribution though. Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432752 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Share Posted November 26, 2014 http://www.sau.com.au/forums/topic/343284-locate-tps-plug-pls-help/ Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432755 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Share Posted November 26, 2014 Is yours the same? Grey one has no wires to it? Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432757 Share on other sites More sharing options...
shubby0901 Posted November 26, 2014 Share Posted November 26, 2014 For mine, they both have cables. I've read that the grey is for auto's but mine's a manual. Perhaps the grey cable isn't connected further down the loom but at the plug, its definitely connected. Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432762 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Share Posted November 26, 2014 Maybe it was converted to manual Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432773 Share on other sites More sharing options...
shubby0901 Posted November 26, 2014 Share Posted November 26, 2014 (edited) Maybe. I've only had the car for a few months. Its got a proper manual gearbox and the gauge cluster is for a manual too. Anyway, so a manual shouldn't have that plug and so its the other brown one. Is there anything else that can cause the rough idle? The revs dont change that much, only like 50-100prm, its more the car shakes. Its not O2 sensor as I disconnected that and still had problems. Revs are adjusted properly because i just disconnected both the grey and brown cable and couldn't get the revs to drop any further than 1000, the screw in AAC is all the way in. I just want to make sure that its nothing major. Edited November 26, 2014 by shubby0901 Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432776 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Share Posted November 26, 2014 That usually means you have a vac leak. My mate had a 33 a while ago. Jumped in it. Saw the. Manual gear stick and to my surprise one of those a/t buttons in the Centre console area. You don't have that? Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432777 Share on other sites More sharing options...
shubby0901 Posted November 26, 2014 Share Posted November 26, 2014 My boost gauge piping had split (for the second time) so I fixed that although I doubt that'll cause the air-con issue. My car has not buttons or anything inside. The only sign of an auto car are the two plugs on throttle body. Maybe they installed a auto throttle body? Not sure but yeah inside the car, there are no signs unless I'm missing something very subtle. Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432801 Share on other sites More sharing options...
Hadouken Posted November 26, 2014 Share Posted November 26, 2014 That's good. Did you try the air con after fixing it? Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7432836 Share on other sites More sharing options...
shubby0901 Posted November 27, 2014 Share Posted November 27, 2014 Havnt had a proper chance to test but initial impressions are that the shaking is alot less violent....so im assuming this vaccum leak could be a factor. Unplugging any sensors had no effect...testing shall continue Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7433254 Share on other sites More sharing options...
shubby0901 Posted December 16, 2014 Share Posted December 16, 2014 (edited) btw, ive seen quite a few series 2 manual skylines with the 2 plugs on the throttle body...maybe all series 2's have it? edit: there are series 1 auto skylines with 1 plug...i think it may be a series vs 2 thing rather than auto vs manual? Edited December 16, 2014 by shubby0901 Link to comment https://www.sau.com.au/forums/topic/433287-r33-air-con-idle-fluctuation-and-stalling/page/2/#findComment-7445584 Share on other sites More sharing options...
