Don't be scared to use it
Ive mentioned before that I had already done the cleaning but am still having the issue therefore I asked in a thread with someone else with the same issue. Infact, I used that very article as a guide.
The second question was which plug was for the TPS, since that article has only 1 plug where as my R33 has 2.
Thanks for the contribution though. :rolleyes:
For mine, they both have cables. I've read that the grey is for auto's but mine's a manual. Perhaps the grey cable isn't connected further down the loom but at the plug, its definitely connected.
Maybe. I've only had the car for a few months. Its got a proper manual gearbox and the gauge cluster is for a manual too. Anyway, so a manual shouldn't have that plug and so its the other brown one. Is there anything else that can cause the rough idle? The revs dont change that much, only like 50-100prm, its more the car shakes. Its not O2 sensor as I disconnected that and still had problems. Revs are adjusted properly because i just disconnected both the grey and brown cable and couldn't get the revs to drop any further than 1000, the screw in AAC is all the way in. I just want to make sure that its nothing major.
Edited by shubby0901
My boost gauge piping had split (for the second time) so I fixed that although I doubt that'll cause the air-con issue.
My car has not buttons or anything inside. The only sign of an auto car are the two plugs on throttle body. Maybe they installed a auto throttle body? Not sure but yeah inside the car, there are no signs unless I'm missing something very subtle.
Havnt had a proper chance to test but initial impressions are that the shaking is alot less violent....so im assuming this vaccum leak could be a factor. Unplugging any sensors had no effect...testing shall continue
  • 3 weeks later...
btw, ive seen quite a few series 2 manual skylines with the 2 plugs on the throttle body...maybe all series 2's have it?
edit: there are series 1 auto skylines with 1 plug...i think it may be a series vs 2 thing rather than auto vs manual?
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
