Car is an r34 4 door GT.
Was factory auto n/a now converted to manual using an rb25det neo box and running a turbo viscous LSD and not the factory open centre with sensor on the side.
Everything is sweet and it's been my daily for the last 4 months. However my speedo is only reading half as it's not connected at the speedo sensor on the box. The speedo sensor just has 2 light green wires coming from it that has been cut and it just dangling. How do I go about hooking this up ? Anyone have a Pinout for this speedo sensor ?
The car is still running the n/a engine and box loom so there is a lot of cut wires under there by the box.
Car is also still running the auto ecu.
Any feedback would be greatly appreciated.
https://www.sau.com.au/forums/topic/433304-r34-manual-conversion-speedo-issues/
I didn't do the manual conversion on this car. But the sensor in the diff at the back on the cog for shaft, if I unplug that, my ABS light comes on an my speedo goes dead. Plug it back in and my ABS works again and my speedo reads half ?
As for the speedo sensor in the box, it's not wired in, it's just 2 bare green wires hanging down.
Given that that doesn't make sense, you can see why I'd ask.
Did the original auto box have a speed sensor that was wired up to the undercar loom?
Have you considered wiring up the speed sensor on the manual tranny to the original undercar loom?
I will point out that I don't know about the R34s autos in particular......but on an R33 manual gearbox there is just two wires from the speed sensor. These give a 0-5v square pulse that is wired direct to the speedo head. The speedo head translates that to a sawtooth (AC signal) at a lower voltage that is sent to the ECU and any other controllers that need speed signal, like HICAS, ABS etc. The speedo sensor on the R34 manual should be the same. BUT....the fact that you also have a speed sensor on the diff, that is somehow giving you a 50% pulse rate to the speedo head is a very strange thing. I'm not sure how they would have wired that up to work if it also needs a gearbox sensor. Just too strange.
On the topic of the auto ECU....how the hell can this be true? The Neo turbo ECU (if auto) has the TCU built into the ECU. The Neo NA ECUs do not, they rely on a separate TCU. You cannot run the Neo turbo engine off the NA ECU. So, if what you are saying is that you have the engine running off a proper Neo turbo ECU and you still also have the old auto TCU box in the car, then it doesn't matter. That old TCU will not be doing anything. The ECU will ignore anything the TCU tries to tell it and the TCU is not hooked up to anything it can influence (except maybe ABS or traction control perhaps).
  • Like 1
The car is non turbo with a DET neo manual box, still running the factory n/a auto ecu.
And I don't know how the diff is giving me a half speedo reading. I don't know anything about the auto setup as it was converted before I got the car.
So I'm wandering, what's the Pinout for the auto loom speed signal and can it be wired to the manual box speedo ?
I find it really difficult to believe that they had different clusters (different speedo heads) between auto and manual cars. Therefore it should take nothing more than hooking the two wires from your gearbox speed sender to the two wires from the cluster (speed signal input). How the hell the diff mounted sender gets involved is a whole 'nother question.
To find the correct wires you may have to get the cluster out and work out which wires go to the speedo (via tracing the circuit on the cluster). The 0-5v signal is polarised, so if you don't get it to work you may need to swap them.
And ..... aaaaah. I see about the ECU now. No turbo. Fair enough. In that case, there is nothing to worry about in that regard. The ECU receives a speed signal - it doesn't provide it to anything. It doesn't care what else you do with the gearbox, so long as it gets some sort of speed signal, which it is at the moment, even if it is strangely half what it should be.
From memory, last time I looked, there is about 6-10 bare wires under there coming from the loom.
Could I simply turn the ignition on and find 2 wires putting out the 5v signal and connect them ? Or will no signal be sent through due to it not being hooked up to the speedo ?
  • 7 years later...
Wow. Notified that someone reacted to my post above (the first one from Oct 16) and realised just now that I completely hamfisted the signals. The gearbox sender makes the +/-1v sawtooth (AC) signal and the speedo head in the dash converts that to 0-5v square wave PWM signal for the ECU.
I must have been on cough medicine that day.
  • 2 years later...
Sorry to revive this topic again Rb20det Gearboxes are caving my head in.
So I have Rb25det With a rb20det manny trans. In my C34 auto converted . the speedo Is reading half the speed and i dont know where to start
So what ive got is the speedo in the gearbox sends an electric signal to the dash which converts it and whats happening is its only getting half ? so do i need an electric converter. Rb25det electric speed sensors are long ones so they wouldnt work with my rb20det one
What sort of speed sensor was used in the C34 auto? An electronic sender like in the typical RB25DETmanua l box? Because, if so, you are shit out of luck. The RB20DET speedo is usually by cable drive. I don't know of any electronic drives for that gearbox. There are for the related 4 cylinder gearboxes in Silvias etc, but I don't know if they are useful.
So, where is this odd "half" speed signal coming from? If you can identify if it's coming from a diff sensor or ABS sensor (ie, that's the original way it was on the C34) then you might be able to just use a speedo adapter box like you can get from Jaycar and various auto-electrical crowds.
Manual non turbo r33 speedo drive should sort it, electronic drive for the 20 box
You know. I'm a bit dense. I should have thought of that! It's not as if I didn't fit an R34 NA box to my R32 at one point, and removed the electronic sender from it!
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
