The next round of DECA is coming up and we need people to help on the day
We are after a group of around 10 people to be Officials .
The roles will be for timers / starters and marshals.
Most important are the morning events and we only need 4 officials in the afternoon.
We would need all volunteers at the DECA complex by 8am and ready for a officials briefing at 8.45
If you are not entered and are just coming up for a look we really need your help
Lunch and drinks will be provided on the day and if you head out with us on Saturday night drinks seem to just get put in your hand through out the night as a thanks .
So if you can help or know someone who can let me know.
Cheers WayneO
Morning
Skidpan
Starter
Timer
Marshal
Mini Wang
Starter.....Clive
Timer
Marshal
Long Wang
Starter
Timer
Marshal
Marshal
Marshal
Afternoon
Skidpan
Starter
Timer
Timer
Marshal
Marshal
https://www.sau.com.au/forums/topic/433307-deca-volunteers-officials/
Hi ,
I’m heading up to Shepparton to be a spectator for the DECA Meet but, i wish to volunteer for your marshal duties, i have some experience in marshalling .
If there is any rooms left at Shepparton i wish to book one.
Hi ,
Cheers Jason.
I was hopeing to get to meeting to have a chat but didn't happen.
I look forward to see you up in shepp.
Post up in the accommodation tread. Bec will try and hook you up a room.
Hey mate, no experience is necessary, they'll be given all the training they need on the day. Girlfriends / Boyfriends / Friends / Partners... all welcome :D
Remind them to bring a hat and sunscreen because the weather is looking wonderful.
Odium, hitting limiter on lower dandenong road with me too early in the mornings ;) I drive the white 180sx
Ha! Oh Hai...
I've got one mate good to volunteer but worried he'll stuff up some how. He's happy to do it though. His name is Marcus
Literally not possible... He could be positioned as a spotter if needed, its a safe place close to the action and all he really needs to do it yell out over the walkie talkie if something goes wrong. Tell him not to stress :D
Guest
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
