General Nissan application, used parts
Spark Plugs - NGK R PFR6A11. Set of 6, one fouled $10.00 for the set. Travelled about 100kms.
Spark Plugs - NGK Laser Platinum PFR6A - 11 4065. Set of 6, one fouled $100.00 for the set. Travelled less than 70kms.
Nissan Skyline R31 Parts
RH front indicator unit (two stone fractures) $5.00.
LH fender indicator unit $10.00.
Hazzard light switch, RR Wash and one that's unknown. (functioning but not good condition) Two blanks, one big, one small $25.00 for all.
RB20DET Ignition Coils x2 $50.00 each.
Nissan Skyline R34 Parts
RB25DET (R34 Neo) Ignition Coils x7. Six of them in genuine Nissan packaging Part# 22448 - AA100. One is suspected to have failed. $200.00 for the seven.
R34 side fender indicator units (pair) $30.00.
R34 HID power units (pair) $100.00.
HID Globes - Philips D2R $20.00 each (5 available)
HID Globes - GE 9011 $20.00 each (5 available)
Pick up or Australia Post, price dependent on what you buy (weight/size). All prices in $AUD.
Please Private Message, email [email protected], or phone Michael on 0419 006 252.
Edited by R-sanyon
https://www.sau.com.au/forums/topic/433309-r31-and-r34-parts/
  • 2 months later...
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
