Hi All,
Am new to this forum, which I just stumbled upon 5 hours ago. Am thinking of
getting an R33 GTST for my first car and need some advice:
a) Is this a good version for entry level skyliners?
b) What is a recommended market price I should be looking at for a fairly original(non modified) R33 or R34 (GTST)?
c) How much does maintenance cost, approximately in a quarter - (am planning to use it as a weekend car)?
d) Any good pre-owned sellers/sites to recommend?
e) Typically how much would the insurance and rego set me back by, as I am on a limited budget.
I'd appreciate all your feedbacks as I need all info I can get before I take the plunge.
Thanks, mates!
Cheers
https://www.sau.com.au/forums/topic/433314-newb-introduction-melbourne/
welcome.
theres alot of info on this site about buying a skyline and the checks to do.
so, to try and answer your question....
a) yes. they can be a good introduction to skyline.
but, what do you want eventually?
you may as well buy the car you want to own eventually.
b) in regards to price, the neater the car, generally, the more you will pay.
have a look around and get a good idea of what most are going for, then progress from there.
c) maintenance, how much do you expect to drive it?
I know you have stated as a weekend car, but mine is, and Im lucky to do 100-200kms a month.
you may do that every weekend.
general maintenance shouldn't be too much more then every other car.
d) sites to look at are the for sale, whole cars on this site.
ebay.
gumtreee.
carsales.
again look at as many as you can, and get a good grasp for price.
e) cant help here sorry, as im in nsw, but hopefully a vic person can chime in with some experience.
either way good luck with your hunt.
and be sure to post pics when/if you buy one.
in the meantime, post pics of your current ride, as we love all cars here, not just skylines.
Hey mate, welcome to the forums! :cheers:
I'm from Melbourne and would advise to either buy from a private seller (after getting the car checked out of course) or from a trust dealer, have a look at some threads and it lists which dealers are good and which aren't and go from there so you don't find yourself in a lemon!
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
