R32 Gtr Seats Vs R34 Gtr Seats
mazza69
 Share
I put 34 GTR seats in my 32 GTR. The 32 seats are way to narrow in the shoulders for me. Suggest you sit in a 34 GTR seat before you buy it/them, since they're not cheap and you want to know they feel right for your body before you throw the coins. Bolt straight it - easy job.
  • 2 months later...
Hey guys, I can't have acces to BNR34 seat because they are not allowed in my state. However, from picture, it appears the shoulder and lower curves more than R32 meaning it should hug more but then some peoples suggest that the R34 is wider so actually the r32 hug tighter ??
Thanks guys :)
Im going to be different to everyone elses posts.... The 34 seats are of course much more comfortable and being so much newer in better nick in general.
But i have had 32, 33 and 34 gtr seats and none hug me at all. im 6 foot 2 and skinny.
If your upgrading because you think they hug alot more i dont think its worth it, but if your going for comfort, looks and condition, defiantly worth it
  • 4 weeks later...
  • 3 years later...
Reviving for my two cents.  I'm a fairly fit and thin dude.  I was thinking about getting the R34 seats for my R32 just to get something newer and in better condition.  However, after sitting in them, I couldn't bring myself to do it.  They feel like regular run of the mill seats where as the R32 seats hug a lot more.  Nothing compared to a racing spec seat, but still way better, in my opinion, than the newer seats.
It sucks because now I have to figure out what seats to get.  >.<
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
