Hey, so i was getting a few quotes from NAC insurance because they'd insure me for a modded car.
So anyways i sent them a quote for 3rd party fire and theft for rb20de AUTOMATIC completely STOCK r32 Skyline and it came to $850 a year.... and thats with a NCB of 60%
just to put that in perspective... right now in my 4age manual levin im paying $800 for FULL insurance.
So that just seems rediculous price.
How do you guys n gals in NZ get insurance for your "Boy racer" cars. and how much are you paying?
and do you have any recommended companys?
Cheers
https://www.sau.com.au/forums/topic/433324-insurance-prices-in-new-zealand/
27YO Male, 1998 R33 GTS25t with all modificatons declared, including larger turbo, wheels and adjustable suspension, Full cover.
$780 P/A.
Shop around. Best idea is to use a broker. I use Crombie Lockwood.
Just turned 40 (gag), '04 PNM35 Stagea, stock, $430-odd a year I think. Also '96 Commodore, headers, exhaust, 18s, suspension mods, $260 per year full cover all declared. Through ShareNZ brokers.
When I was 31 I had an EK4 Civic with a K20A a 6-speed box from a DC5R Integra in it, intake, headers and exhaust, TE37s, lots of suspenion and brake mods and so on, was $910 full cover and agreed value of $28K.
I'm with NAC since i'm only 23 ( just ) and none of the big companies would insure me, i have a 94 GTS25T Auto 4 door skyline ( pretty much stock ) it cost me $978 a year through NAC for full insurance, $850 seems HEAPS for a not turbo RB20 :/
26yo male.. last time i asked for a quote from nac was last nov/dec for:
R32 gts-t coupe
rb25 turbo. manual
usual mods. h/d clutch, r33 gearbox, link computer, coilovers, full 3.5" exhaust, t3/t04 turbo (garrett)
sound setup value arond $2000
car covered for maximum $10k
was going to cost $1200. so i parked it up instead..
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
