Just built a new house and want to seal the floor of the garage.
so many different products out there i would like to know whats best? i spill oil water etc when working on cars.
i seen in this section many photos of cars sitting on nice clean garage floors
If you can afford to, do a polyurethane or epoxy type floor seal. This is nothing like hardware store floor sealer.
These surfaces are used in industrial high traffic areas, the food factories I've worked in renew them every 5 years or so; as a home garage floor it would be next to indestructible.
You can steam clean, no damage, use jacks etc, no problem. They can be textured or a gloss finish; the gloss is like glass.
get onto http://www.garagejournal.com/forum/ it's basically SAU but for garages / workshops & is quite frankly awesome. Has a whole section on Flooring.
Then recommend getting into the 'garage gallery' section which is basically build threads. Current favourites are The Concrete Underground, 44 Bikes Frame Shop & Mark's Monster Garage but seriously heaps of awesome builds.
Prepare to lose hours / days / weeks...
The epoxy flooring is tough, but certainly not indestructible. I have 2 garage floors done in this stuff (total about 240m2) and if you drop sharp steel objects on it hard enough it will damage the coating. I just finished fabricating a heap of shelving and work benches and dragging 100kg shelf units across the floor (with sharp edges on the end of the feet) does scratch / damage the surface. If you drop something heavy onto the concrete, it'll crumble the concrete underneath and the poly coating will come off.
Still, this stuff is infinitely stronger than paint, so will stand up to general wear and tear (dragging jacks across the floor, pressure washing, oil spills etc.)
Also remember some of it is very slippery when wet.
I used paving/concrete paint from bunnings, and it is starting to wear after only 12 months of weekend use. So depending on price of the epoxy stuff I would go that instead. It still looks good overall and seals oil/water properly but I don't think its going to last as long as I'd like.
Most workshops that use paint redo it every year.
Also it's important to acid etch the floor first or it will flake off early.
Shit, that garage forum will have me stuck for hours!
it seems poly or epoxy is the way to go. bout 499 for 20L which should do my floor and my old mans also tho his will need a fair bit of cleaning or diamond cutting back since its over 10 years old and is fairly worn. both about 6x6m
You want a rough surface for the paint to stick to. It mechanically adheres to the concrete it doesnt react with it. So clean it, degrease it and etch it with either the proper etching stuff or if you know what you are doing and are careful (fkn careful) acid.
  • 1 month later...
so i've done the clean, and sand of the garage floor. @$#%^^$# asian painters and plasterers that did my house are a bunch of messy %@$$^#$%&$%^$%
Did the etch on wednesday afternoon and have now got the first layer of epoxy down its starting to look pretty good. except for the small cracks everywhere.
will grab a photo today after the second coat. i ended up buying the epoxy from csw coatings 10L kit will do two pretty thick coats on my 6x6 m2 floor.
How much was the 10L? I've got a 6X7 garage and 14X8 shed to do, both new concrete.
Would you still need to etch clean a brand new floor? Obviously clean off the concrete dust and give it a good wash but would it need an etch?
Amerlock 400 is the go
My garage is done in this. After looking at dads shed, about 15 years its had the stuff on it and we have dragged, dropped, got thiners, oil etc on it and the only bit that has been damaged is missing a chunk of concrete. The stuff is great
We got it locally at an industrial paint etc supplier, can't remember how much but about 10L did the garage floor, the small shed slab and a little bit of concrete where my small clothes line is. Will try and get a photo in a bit
bout 300 i think i spent. acid, masks, paint rollers and metal paint pole + other shit
i had to sand my floor in many places, and get the high pressure hose on it , and yep etch is a must unless you grind.
i mixed half the 10l bucket and did two coats for 6x6 and had enough left over to do a fair bit more so a 20L would get you done with two coats.
Would anything like this be OK? Or not worth the bother? Not cheap by any means.
I just need to paint half the concrete floor of a double garage.
http://www.bunnings.com.au/berger-jet-dry-10l-heavy-duty-evening-stone-paving-paint_p1410009
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
