Hey fellas,
Got a hold of a hoist recently (best thing ever might i add), but just wondering where the hell do i put the arms under on the R33?
The rails look pretty soft...so just thought I'd ask this silly question before i go and stuff something up!
https://www.sau.com.au/forums/topic/433335-hoist-spots-for-lifting-r33-gtr/
I use the stock jacking points, don't use the chassis rail inboard of it, they are way too soft.
Took my car to a mechanic about a year ago and he somehow caved in my jack points :(
Ps: totally random comment, but I just felt the urge to mention it :P... Lol
Slightly OT but if using a trolley jack, I've always used front sub-frame/rear diff. Is that generally considered the right place to use? I've heard people say use chassis rails, but as stated above, they seem pretty soft.
Never on those "chassis rails"! Unless you want a very expensive repair bill to fix them, they are soft and not for loading on at all :no: . There are axle stand points on the sills front and rear I believe, also some hoists appear to have additional inboard blocks to lift up the chassis on the diff/subframe area though I'll assume you have a 2 post hoist with the adjustable arms so the sill points will be the go with appropriate soft blocks/pads. Again don't use the "chassis rails" as this is at least a $500 repair if you get caught with the damage.
Hope that helps!
Links;
http://www.skylinesaustralia.com/forums/topic/266324-howwhere-to-lift-a-skyline-r33s2/
http://www.skylinesaustralia.com/forums/topic/118956-jack-stand-points-needed/
^Side member=NO LIFT NO! ;)
Thanks for all the reply's fellas, Havn't had a change to throw it up on my lift yet, but was happy i remembered reading somewhere "Don't lift on the chassis rails" ha ha as my old man told me to put it on there!!
When you say the jacking points ( I have never used them on the skyline, I always used to jack from the cross member up front and the diff on the rear), are you refering to the metal tab/cut out looking things just after the front wheels near my side skirts? There are also some just in front of the rear wheels too.
I have uploaded a picture of my hoist pad, as it is all still pretty new to me!
And yes - It's a 2 post hoist where the arms are of adjustable length
Also - What are sill adapters?
Edited by Booki
The jacking points will be on the sills (just in from the side skirts).
Pretty sure there meant for emergency jacking only but for a hoist there really the only place you can use.
And that pic you have is basically what every hoist should have anyways, they should all have rubber pads.
I took a few snaps - i assume these are the sills, and like everyone else. Mine look like they have been damaged....so don't know if they are safe to lift on? I don't want to wreck them more :\
Can you lift from this point on the suspension?
I have circled the area, although that only covers the rear....anywhere else i can go from the front?
Those are the right points, they're standard locations on most cars Ive worked on. Behind the front wheels and infront of the rear wheels. And yeah don't jack up on the chassis rail.
Good to see in that pic up there Booki that your jacking points are still in good shape, both my cars are flats because the wrong jack was used. I now lift from the rear under the diff and the front, where ever I see fit.
The load point is the flat section between the two half circle cut outs, if you look at the factory jack it has a cut out in it which is to allow the bit that sticks down to go into, so the concept is the same for the hoist, make sure the bit that sticks down goes into a cut out
NEVER lift from the chassis rails
Is there anywhere else you can lift the car up from? (Using a 2 post hoist)
Can't grasp the concept that the little bit of metal sticking out where you put your emergency jack is where you lift the car from, maybe I am looking at the wrong thing.
How do peoples get damaged if hoist pads have cutouts in them?
Edited by Booki
  • Like 2
They don't if you lift the car level, with all 4 pads on the correct spot. The jacking points on the sill are reinforced to handle it, just take it easy and make sure the pads are central as you lift.
  • Like 1
hijackin the thread - but is it possible to get my jack points repaired? they are completely screwed up... :(
A little heat a large flat blade screwdriver and a shifter should have most of it bent back, depending how it has folded, but it will have limited strength afterward
I find they crush when most of the car's weight is put on to one point. That's why a trolley jack on the front point works fine, as do hoists when balanced properly.
Alrighty!
Actually got off my ass and had a good squizz at the car.
As you guys have said, you can tell where the lift points are and how it works after looking at it with the pad under neath it (and comparing to the factory jack lol).
But....the pads I have are not deep enough to totally prevent sill damage, it will hit the sill when i lift.
anybody know of any other type of hoist pads or adapters i can use to be 100% safe not to damage the sills? (Yes im fussy like that :P )
The genuine nissan one is LM4086-0200
Havn't been able to find it online yet
Edited by Booki
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
    • These things happen And I believe "we, the people, who modify stuff, and actually use it, cannot have nice things" It's just a shame that it happened so soon after paint  I still win the award for quickly destroying newly painted panels I think, as my car came back from the paint shop all nice and shiny, until about 4 hours later when the boot was destroyed by a wayward locker that was blown around by the wind.... What doesn't kill you makes you stronger, and poorer.....dooh
    • This. And also, the rotor thickness is constrained by the calipers. Cannot be much thicker, if at all. Cannot be much thinner, if at all. New rotors are....fairly cheap. Turbo calipers can still be picked up for sensible money. Arguably, the best thing is to get R32 calipers and put them on mount spacers on 324mm discs. That's about the cheapest and easiest way to get quite large brakes that are essentially bolt on. And that's despite maintaining for years that the R32 calipers are not the best choice because they seem to be more flexy and creaky than the others. If you were prepared to put up with nasty little NA sliding calipers, these will still seem like Brembos by comparison.
    • A quick Google said 297mm..
