square hollow section/ metal post
http://www.moorabbinsteel.com/shs.php
with a grinder or drop saw cut a slit it in it like the factory jack and place that on the sil panel jacking point to spread the load better for the hoist
Thought about that, but would want something that wouldn't have such a harsh edge on my hoist pads or the list points of the car (pending which way you cut it)
Then the added stuffing around making sure they are lined up and in the correct spots on every point of the car while lifting seems annoying.
Hoping to find another pad with deeper grooves for this purpose so its just as easy and lifting anything else.
Just a quick line up and check and up it goes, instead of having to worry about the bracket/tubing on my pads being on a slight angle, or not in the middle of the hoist pads, worst thing i am afraid of is if i am working on the car, and have to apply a bit of torque to something and a bracket tips over. could result in my car being sad, or myself having no emotion at all lol!
Unless i am thinking about it the wrong way, or maybe I am just too much of a fussy prick.
I would have to weld up a base plate to sit on my pads to make it extra safe, even then if it slips off due to incorrect lifting is also a possibility
Edited by Booki
The M35 stagea is two ton with similar strength sills, I doubt a skyline would crush the sill if the load was evenly balanced. (unless it was already damaged) None I have had on the hoist have ever crushed anyway. You obviously need to be careful though, centering the load on the pad.
If you are worried, sit a length of wood between the pad and along the sill spreading the load over a greater area.
How do you think people lift up the car with a trolley jack?
When I jacked my lifted the car up with my hydraulic jack, I used the cross member with a block of wood. And the diff for the rear...
I am looking at deeper style pads so it makes no contact with the sill, only the load points.
Yeah I think I have ocd
Most of the cars I see are lowered and there is no way I could get to the crossmember. I need to jack most up just to get the hoist pads under it, and they are only 100mm off the ground.
Fiberglass side skirts really shit me.
After much hunting around and calling endlessly, finally found a bloke who sold me the pads in vic!
Picked them up today and they fit pretty well under neath, they are about 15-16mm deep, vs the 10-12mm ones i have.
Lifted the car up and no issues!
He has pads for all different types of hoists too
  • 9 months later...
You wouldn't still happen to have the number of this bloke by any chance? I'm after some of these adapters as well.
His name is John,
Really nice guy and got me a pad with a thicker groove so it did not contact the sill, only the mounting points. Basically mimicked the factory jack.
www.johnwards.com.au
It's funny, after all this time you could have just lifted up the car on those standard hoist pads and not had a problem. It doesn't look like they fold in enough at all, but believe me they will. You can lift it up with a rubber block with no cutouts in it and it still won't damage the sill.
Do you think that applies to all cars? not just GTR/skylines?
And would the pad have to be on that exact spot with the cutouts on the sill? or could you lift it proportionally down either side?
Yes, all cars are designed to be lifted at the sill, many workshops use flat rubber pads to spread the load, but there is only 1/4 of the car's weight on each pad.
The issue comes when dropkicks jack from one sill with a trolley jack and don't take care/spread the load.
I have on numerous occasions lifted a car from before or after the cutout because the car was positioned incorrectly in the middle of the hoist. Obviously you aim for around the spot that the cut out is in (they're like that to show you where to put the standard Nissan scissor jack), but before or after is fine.
Interesting, because we have a few other cars in our house hold, and the hoist arms are not "short" enough to reach the factory jacking points, resulting in the pad being a little bit before or after depending how centered the car is.
Would it be better to have the pad so the cutout goes into the sill or have it so the sill rests on the outside of the pad? (probs a dumb question now that i read it back)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
