square hollow section/ metal post
http://www.moorabbinsteel.com/shs.php
with a grinder or drop saw cut a slit it in it like the factory jack and place that on the sil panel jacking point to spread the load better for the hoist
Thought about that, but would want something that wouldn't have such a harsh edge on my hoist pads or the list points of the car (pending which way you cut it)
Then the added stuffing around making sure they are lined up and in the correct spots on every point of the car while lifting seems annoying.
Hoping to find another pad with deeper grooves for this purpose so its just as easy and lifting anything else.
Just a quick line up and check and up it goes, instead of having to worry about the bracket/tubing on my pads being on a slight angle, or not in the middle of the hoist pads, worst thing i am afraid of is if i am working on the car, and have to apply a bit of torque to something and a bracket tips over. could result in my car being sad, or myself having no emotion at all lol!
Unless i am thinking about it the wrong way, or maybe I am just too much of a fussy prick.
I would have to weld up a base plate to sit on my pads to make it extra safe, even then if it slips off due to incorrect lifting is also a possibility
Edited by Booki
The M35 stagea is two ton with similar strength sills, I doubt a skyline would crush the sill if the load was evenly balanced. (unless it was already damaged) None I have had on the hoist have ever crushed anyway. You obviously need to be careful though, centering the load on the pad.
If you are worried, sit a length of wood between the pad and along the sill spreading the load over a greater area.
How do you think people lift up the car with a trolley jack?
When I jacked my lifted the car up with my hydraulic jack, I used the cross member with a block of wood. And the diff for the rear...
I am looking at deeper style pads so it makes no contact with the sill, only the load points.
Yeah I think I have ocd
Most of the cars I see are lowered and there is no way I could get to the crossmember. I need to jack most up just to get the hoist pads under it, and they are only 100mm off the ground.
Fiberglass side skirts really shit me.
After much hunting around and calling endlessly, finally found a bloke who sold me the pads in vic!
Picked them up today and they fit pretty well under neath, they are about 15-16mm deep, vs the 10-12mm ones i have.
Lifted the car up and no issues!
He has pads for all different types of hoists too
  • 9 months later...
You wouldn't still happen to have the number of this bloke by any chance? I'm after some of these adapters as well.
His name is John,
Really nice guy and got me a pad with a thicker groove so it did not contact the sill, only the mounting points. Basically mimicked the factory jack.
www.johnwards.com.au
It's funny, after all this time you could have just lifted up the car on those standard hoist pads and not had a problem. It doesn't look like they fold in enough at all, but believe me they will. You can lift it up with a rubber block with no cutouts in it and it still won't damage the sill.
Do you think that applies to all cars? not just GTR/skylines?
And would the pad have to be on that exact spot with the cutouts on the sill? or could you lift it proportionally down either side?
Yes, all cars are designed to be lifted at the sill, many workshops use flat rubber pads to spread the load, but there is only 1/4 of the car's weight on each pad.
The issue comes when dropkicks jack from one sill with a trolley jack and don't take care/spread the load.
I have on numerous occasions lifted a car from before or after the cutout because the car was positioned incorrectly in the middle of the hoist. Obviously you aim for around the spot that the cut out is in (they're like that to show you where to put the standard Nissan scissor jack), but before or after is fine.
Interesting, because we have a few other cars in our house hold, and the hoist arms are not "short" enough to reach the factory jacking points, resulting in the pad being a little bit before or after depending how centered the car is.
Would it be better to have the pad so the cutout goes into the sill or have it so the sill rests on the outside of the pad? (probs a dumb question now that i read it back)
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
