Hello I am a new bloke, am about 35 years of age, sell Suzuki (cars) for a living in Brighton. I get a work car (Swift Sport usually) so want something old and cool to look at in the shed and take for a run to the hills every now and then. I have done a bit of drag racing in V8's in the past and I had a lot of fun, so might consider that too. I am pretty keen on getting an R32 GTS T of all things - I realise this is near the bottom rung of Skyline ownership but as a pure driving experence I prefer lightweight, rear drive cars... Plus I like the look of 'em. Plus I reckon the RB20det is one of the best sounding engines ever. I was looking at S15's for a while there but in the end I decided the SR sounds about a tenth as good as an RB and that was important, plus I reckon I can get a decent 32 for a bit less cash and leave some aside for fixing it up.
I had a silver 4 door manual r32 GTS T Type M when I were a young 18 year old back in NZ and ultimately that would be what I'd have again, but I'm not too fussed. I like the stock rims more than any others I've seen, and I don't like any body kit aside from the little boot spoiler. Not even the Type M side pods - although they apparently disguise rust quite well. :-) I prefer to keep the mods to just breathing, cooling and a bit of tuning, I find anything more tends to turn into a bit of a money pit. Am also a fan of cars lowered slightly on stock rims, dunno why. Probably because the car's designers knew what would suit the car best I guess. I do concede plenty of stock rims are rubbish tho.
Once thing I've noticed looking at Skylines is that auto cars are heaps cheaper than manuals, and they often seem to be a bit less messed with and thrashed, so I might consider an auto if it was otherwise pretty mint. I quite like auto turbo 6's (ie XR6 Turbo's) It's fun when they kick down, plus they're better for drag racing. I also get a sore left knee too which sucks with heavy clutches and whatnot. (The Swift has the lightest clutch ever)
I can always convert it to manual down the track can't I...
There is a very nice R32 GTS T on Carsales at the moment that a Dealer wants about $14k for - ha ha ha. Yes it is nice and stuff but geez, that is quite a lot. Maybe they're anticipating it'll be a future classic?
https://www.sau.com.au/forums/topic/433341-hello-from-elwood/
Welcome aboard the SAU forums... Like your taste of motor - I definitely rate any rb over the sr's :)
Good luck with your car hunt.
Ps: wouldn't pay 14k for an r32 GTS-t... Another 5k and you'll get the r32 gtr ;)
Thanks mate. Yeah it is rough GTR money they're asking... Crazy town.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
