I'm in the market for some new car insurance for my m35 as the pricks i have been with (just cars) decided to bend me over and f**k me hard,So i thought I'd ask who other people are with as a lot of company's wont touch our cars.Cheers
https://www.sau.com.au/forums/topic/433346-car-insurance/
Last I heard Lumleys wouldn't touch the M35, not special enough or something.
I am insured with Shannons, around 1k and no lockup living quarters. Out in the rain with no farks given. They were fine with it.
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7063411
My last one was insured by Lumleys. End of the day these guys just pick and choose which customers they want - same with Shannons.
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7063437
  On 14/10/2013 at 9:58 AM, Commsman said:
You could try calling Enthusiast http://enthusiast.com.au/
Not sure what price for DD, but I paid $454 last renewal as I don't drive mine often.
That sounds better,ill give them a call thank you.
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7063523
Mines currently insured through Lumleys. Haven't had to speak to them, touch wood.
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7063531
Everyone will be different, not much point in comparing premiums from what I've heard from people in the industry (who are active here on SAU, too).
Age of car, condition of the car, features and mods, location, driving history and driver's age, and usage all play factors in quoting premiums, so no two situations will ever be quite the same...
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7063698
I used to have my R33 insured with Lumley Special Vehicles, when I got my R34 and just wanted to change it over they said that they have to close off my current policy and open a new policy.. BUT as it's a NEW policy on a SPORTS car, they cannot insure me anymore as they ONLY INSURE CLASSIC CARS NOW, sooo basically told me to go f*** myself!! It didn't make sense as they were insuring my R33, but their response was that they will continue to honor all OLDER policies until such time they are closed. Tried speaking to the CEO and basically muttered the same shite, so told them the go jump!! I did have insurance with AI for a while http://www.aiinsurance.com.au/ who weren't too bad. I'm with Shannon's now and it's up around the 1k mark Rating 1
https://www.sau.com.au/forums/topic/433346-car-insurance/#findComment-7064167
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
