Huge r32 gtst part clean out
R32 parts
Blue face cluster 80
Left dash vent 60
Black electric mirrors 60 ea
Clear indicators, immac- offer
Jensen 6x9s, with the wood spacers for r32 doors 60 both
Head lights 125 ea mint condition
34 mm water temp adapter 10
Drivers window swtich 60
5 bolt shafts 75 pair
Door cards with speaker grills in decent shape 50 ea
Drivers seat with small rip 30
Passenger seat immac 40
Gk tech hicas lock bar 65
A pillar covers 25
Floor carpet in awesome shape ( I think) 40
Gab front shocks has springs on them assume lowered 70
Passenger door glass 20
Rough stock steering wheel 20
Brake booster 50
Full set of working good condition locks with key 90
Drivers door in good shape, with window in black 140
Rear windscreen, you cut it out $50
Right side front quarter panel in black, few scrapes from storage 70
rb25det s1 parts
cam shafts in good condition, 180 pair, 100 ea
rb25 crank/ cam angle sensor 100
stock manifold 40
cam retainer thingos 10 ea
might have a few other parts i am forgetting
coil pack loom, few chipped clips and stuff works 100% 70
rb25det s2
stock coil packs 100 for 6, one is no good apparently
also have a complete rb25det s1 long motor bought it for my r32 but decided to stay rb20
it has turbo manifold, intake manifold, flywheel and rocker covers all bolted on. was behind an auto stock turbo r33 with 140,000ish kms
timing belt in good nick, head looks in good nick. was told it was running great and the bloke i bought it off seemed genuine
very open to inspections/ tests, but there is no starter and no oil in it,
I would like to see 1000 for it, negotiable but no stupid prices, and i can negotiate above parts for cheaper if you buy engine.
Shoot me an offer, worst i can say is no
Bring your own engine crane, or I can have it put in my trailer and i can bring it for some fuel money
Might swap for
-right side quarter panel with decent black paint
-intercooler and/or piping for rb20
-rb25 turbo
Everything works unless stated and I will give money back if it doesn't.
Have lots of other stuff from a black gtst
Prices are pretty firm, but shoot me an offer if you think its unreasonable
All located Altona, Victoria.
Can post small things in prepaid bags (easiest way)
Can send photos upon request (sms me)
Don't waste my time and I won't waste yours
My number is 0433200452, I work a fair bit so text me or you can call and i'll do my best to get back to you
I will endeavor to check my PM's but i always forget about them
Thanks guys
Also have fuel tank 150
rear wiper arm and blade 35
6x rb20det/rb25det s1 coil packs, work great,100 for 6
i have boxes full of stuff so send me a text and i might have what you're after.
note: i dont have any 5 stud hubs or brakes
taking offers on the rb25det engine,
cheers
  • 3 weeks later...
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
    • I agree, and yet my "HRM " hat is also on, as his wideband is in disagreement with the narrowband where they used to play closer attention to each other.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
