I imported an R34 GTR V-Spec2 last year and it came with HKS Hipermax 2 suspension fitted.
The left rear shock has blown a seal so I'm going to replace the suspension.
Did a search and read through this topic:
http://www.skylinesaustralia.com/forums/topic/374385-bilstein-coilover-conversion/
Need people's advice/experience.
My plan is to get Bilstein B6 shocks:
Front part No. 24-021074 (old part no. B46-2107)
Front part No. 24-021081 (old part no. B46-2108)
and:
ISC rubber mount strut tops to suit 2.5" spring
Sleeves to suit Bilstein shock (A1 racing, part no. A1-12451)
2.5" lower perch to suit sleeves (A1 racing, part no. A1-12460)
bushes & washers to suit
I'm not sure what spring rates or lengths to use yet.
Based on what other people have used, and the fact that the BNR34 is heavier, I'm guessing 325 lb/inch front and 275 lb/inch rear?
And will these spring rates work OK with the Bilstein shocks or will I need to have them re-valved?
As far as the spring lengths go, I figure I'll get the shocks all assembled then work out how long they need to be.
For the bump stops, where do I get them from so I can cut to suit the block height?
And is 30mm about the right measurement to avoid block height occurring?
And excuse my ignorance, but what fixes the sleeve to the shock? I see mention of having to have grooves machined in the shock body to accept a circlip but I can't picture how this works.
Where's the best place to order the shocks and springs from?
Edited by guppy
I'm not sure what spring rates or lengths to use yet. As far as the spring lengths go, I figure I'll get the shocks all assembled then work out how long they need to be.
For length your choice with an Eibach spring is either 8" or 10". 10 for the back easy, 10 for the front if you can. Both may need the extra groove put onto the shock body to accomodate them. Would suggest 10" all round but the front ride height may be a problem so get the grooves put under the existing ones (down aways too). How long is your sleeve?
6kg/mm & 5kg/mm are reasonable numbers. Bilsteins will be fine in this range. You would be surprised how large a srping variation they can accomodate.
Stock bump stops are good if you have them. You have to try before you can get them to length. This is a pain but has to be done.
If you have a look at the other thread the photo in post 12 shows the circlip in the top groove. Tiny circlip is tiny but is trappped by the bottom of the sleeve.
OK thanks Richard.
Do you have an opinion on the different types of nuts for the threaded sleeves? I think I'd prefer the two locking nuts as opposed to the single nut with what appears to be a grub screw to lock the nut onto the sleeve. But most of the threaded sleeves I come across on the net are the latter type.
Not really, no. I have the two lock nut type but they can be a bitch to get off and sometimes a bitch to get enough torque on them to tighten properly. The other type there is a bit of a worry about hurting the thread. But ultimately I dont suppose it matter much either way.
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
