I imported an R34 GTR V-Spec2 last year and it came with HKS Hipermax 2 suspension fitted.
The left rear shock has blown a seal so I'm going to replace the suspension.
Did a search and read through this topic:
http://www.skylinesaustralia.com/forums/topic/374385-bilstein-coilover-conversion/
Need people's advice/experience.
My plan is to get Bilstein B6 shocks:
Front part No. 24-021074 (old part no. B46-2107)
Front part No. 24-021081 (old part no. B46-2108)
and:
ISC rubber mount strut tops to suit 2.5" spring
Sleeves to suit Bilstein shock (A1 racing, part no. A1-12451)
2.5" lower perch to suit sleeves (A1 racing, part no. A1-12460)
bushes & washers to suit
I'm not sure what spring rates or lengths to use yet.
Based on what other people have used, and the fact that the BNR34 is heavier, I'm guessing 325 lb/inch front and 275 lb/inch rear?
And will these spring rates work OK with the Bilstein shocks or will I need to have them re-valved?
As far as the spring lengths go, I figure I'll get the shocks all assembled then work out how long they need to be.
For the bump stops, where do I get them from so I can cut to suit the block height?
And is 30mm about the right measurement to avoid block height occurring?
And excuse my ignorance, but what fixes the sleeve to the shock? I see mention of having to have grooves machined in the shock body to accept a circlip but I can't picture how this works.
Where's the best place to order the shocks and springs from?
Edited by guppy
I'm not sure what spring rates or lengths to use yet. As far as the spring lengths go, I figure I'll get the shocks all assembled then work out how long they need to be.
For length your choice with an Eibach spring is either 8" or 10". 10 for the back easy, 10 for the front if you can. Both may need the extra groove put onto the shock body to accomodate them. Would suggest 10" all round but the front ride height may be a problem so get the grooves put under the existing ones (down aways too). How long is your sleeve?
6kg/mm & 5kg/mm are reasonable numbers. Bilsteins will be fine in this range. You would be surprised how large a srping variation they can accomodate.
Stock bump stops are good if you have them. You have to try before you can get them to length. This is a pain but has to be done.
If you have a look at the other thread the photo in post 12 shows the circlip in the top groove. Tiny circlip is tiny but is trappped by the bottom of the sleeve.
OK thanks Richard.
Do you have an opinion on the different types of nuts for the threaded sleeves? I think I'd prefer the two locking nuts as opposed to the single nut with what appears to be a grub screw to lock the nut onto the sleeve. But most of the threaded sleeves I come across on the net are the latter type.
Not really, no. I have the two lock nut type but they can be a bitch to get off and sometimes a bitch to get enough torque on them to tighten properly. The other type there is a bit of a worry about hurting the thread. But ultimately I dont suppose it matter much either way.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
