Hi All
Selling my 1990 180sx. It's a little rough cosmetically, but drives great! I have the interior (rear seats/trim) and it will be included but not installed. When I ran it at Eastern creek a few months ago I ran a 12.8@118mph with almost bald tyres and stiff coilovers, and lots of wheelspin. So with some decent rubber a low to mid 12 would be easily achievable.
Mods are as follows (Probably some i cant remember as I am writing this off the top of my head at uni. Ill update as i get time)
Kilometres: ~ 195000Km
Engine/driveline:
- SR20DET standard internals with cams (unsure of duration and lift)
- TD06 25g with external wastegate (I think its a trust 80mm) and screamer pipe
- Hybrid FMIC
- Full exhaust with false cat.
- Adjustable blow off valve
- Apexi power FC tuned by JEM to 255rwkw @ 21psi dyno sheet provided.
- Heavy duty organic clutch
- Heavily shimmed LSD, acts like a locker in carparks etc.
- Oil catch can
- K+N pod filter
Suspension:
- ISC coilovers 8Kg/mm front and 6kg/mm rears. Have some old stiffer coilovers that can come with the car if wanted.
- Rose jointed/adjustable castor rods.
- Rose jointed/adjustable adjustable rear upper control arms.
- Whiteline adjustable swaybars front and rear.
- Strut braces front and rear.
- 17x8 and 17x9 Wheels Front tyres are 90% tread KU38, rear are cheap tyres with around 10% tread. May replace before sale.
- Hicas deleted
- Project mu HC+ pads with slotted rotors at front. These pads are near new. Awesome bite and fade resistant.
- Wheel aligned recently.
- Also have 2 17x7 lenso skid/drift rims, and 4 14x6 skid/drift rims.
Interior:
- Aftermarket steering wheel
- Gearknob, drift button.
- Some pioneer head unit with crap speakers in the doors.
- Boost gauge
- Passenger seat is a type x seat.
- HID headlights.
Ill post up some engine shots soon.
For photo's : http://classifieds.nissansilvia.com/...vert&t=2279398
Rego until Nov 2013. Any questions feel free to call me on 0433046780.
Thanks
Tim.
  • 4 weeks later...
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
