For Sale:
1996 Series 2 R33 GTST Black.
159,000ks
Genuine Greddy front mount
Apexi RS coilovers...
3inch turbo back exhaust with bellmouth 3.5inch staino dump.
Blitz Blow Off Valve
Blitz oil cooler
Apexi pod with stainless intake. also comes with standard intake as well as air box. Don't have air box snorkel
Greddy Profec B Spec 2 boost controller
Genuine Russian Desmond Regamaster Evo rims
17x8 +35 front and 17x9 +38 rears
Painted black originally white. Seriously rare rims.
JVC Head deck with 6s in the doors and 6x9s on the back tray
Serviced every 5000ks with new oil, filter, fuel filter, air filter cleaned with k&n cleaner and oil and afm and throttle body cleaned.
New Spark plugs every 10000 also.
It is my pride and joy and I will be sad to see it go, but I just don't have the time for it anymore.
I want $10,000 for it but throw me a descent offer. Dont want to swap for anything.
Has a key mark down the drivers door from front to back.
Amazing car. Handles amazing and doesn't stand out too much.
  • Like 1
https://www.sau.com.au/forums/topic/433389-1996-black-r33-gts-t-newcastle-nsw/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
