No need for these so make an offer if you need something
Located at Mt.Gravatt Bribane,can drop them off or send with a Courier.
Message me for a contact number.
Info on the brand new bearing kit[will fit all series 2 rb25det's apparently including Stagea's]...copied from the email Andrew at KUdomotorsports sent me recently...
These item's listed are common to all twin cam RB engine:
-Cam / Crank Oil Seal - Genuine Nissan CA18DE(T), RB20E(T), RB20DE(T), RB25DE(T), RB26DETT, RB30E(T) & VG30DE(TT) - $11.00ea (you’ll require 3)
-Timing Belt Bearing Kit - NSK / Genuine Nissan - Nissan Skyline R32, R33 & R34 DOHC (RB20DE, RB20DET, RB25DE, RB25DET & RB26DETT, Inc Neo 6) - $113.30, and includes:
-1 x Genuine Nissan Tensioner Bearing Spring
-1 x NSK Timing Belt Idler Bearing (Nissan OEM)
-1 x NSK Timing Belt Tensioner Bearing (Nissan OEM)
Total[that i paid last year]: $146.30 + postage
...I'm asking $120 ono
Altia[??] rear wing from r34 gtt only a few light scratches
Both supports are abit loose but can be repaired
$70 ono
Starter motor from r34gtt bought from Kuodmotorsports this year
Didn't fit my Stagea
$70 ono
HKS atmo Sequential BOV with rb25det adapter
Its a copy but,was on car when i bought it
$30
Neo rb25det engine cover for r34gtt/Stagea
$40 ono
New DRIFT shiftknob with thread adapteres
Paid $60 sell for $40 ono
  • 11 months later...
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
