I need to replace both the reservoir hoses, but nissan says they can't/won't supply the part. They say its stagea specific and nissan australia doesnt supply it.
Anyhow I have some oil safe hoses ready to use, the smaller diameter P/S hose isnt a problem, however the larger one is trickier.
The inlet on the pump is 15mm diameter. I have some 5/8 inch hose which is just slightly too large. It will seal on the flange of the pump inlet but its still slightly larger than 15mm.
I have some 9/16 steel braided hose being delivered to try out and see if that will work (its about 14.2mm ID)
I would still like to try and make the 5/8 hose work as I have some angled hose braces that will allow me to bend the hose and keep the shape.
I was thinking about slightly increasing the diameter of the pump inlet with heatshrink, which is also a fairly pliable plastic and should make a good seal.
Any one else have solutions?
https://www.sau.com.au/forums/topic/433448-c34-ps-resevoir-hose-ideas/
The 14.2mm hose should work nicely.
I hope so, my main concern is the tube kinking on sharp bends, particularly since the larger hose is a suction hose correct?
The 9/16 hose on its way to me should have a wall thickness of around 3mm or less, whereas the 5/8 tube I already have is 4mm.
Also I have a few 5/8 unicoils (http://www.unicoil.com.au/) which will work perfectly for bending the larger hose.
If the hose is available from Nissan, your dealer can get it.
Sounds like they're just being obtuse. Navigating the unfamiliar sections of FAST took my local dealer a while, but they were happy to help me.
Well my custom jobby turned out fairly neat. I put some 13mm I.D. PVC clear pipe over the fittings to give a firm seal with the 5/8 oil hose. Unicoils stop the hose from kinking, and I wrapped some old bike tyre inner tube around the whole thing, since the original ones had extra insulation too.
Still its a real close fit between the aircon fitting and the turbo inlet pipe. The original molded pipe has a sharp bend right out of the P/S inlet.
The smaller hose can use 3/8 hose, no modification needed.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
