I need to replace both the reservoir hoses, but nissan says they can't/won't supply the part. They say its stagea specific and nissan australia doesnt supply it.
Anyhow I have some oil safe hoses ready to use, the smaller diameter P/S hose isnt a problem, however the larger one is trickier.
The inlet on the pump is 15mm diameter. I have some 5/8 inch hose which is just slightly too large. It will seal on the flange of the pump inlet but its still slightly larger than 15mm.
I have some 9/16 steel braided hose being delivered to try out and see if that will work (its about 14.2mm ID)
I would still like to try and make the 5/8 hose work as I have some angled hose braces that will allow me to bend the hose and keep the shape.
I was thinking about slightly increasing the diameter of the pump inlet with heatshrink, which is also a fairly pliable plastic and should make a good seal.
Any one else have solutions?
https://www.sau.com.au/forums/topic/433448-c34-ps-resevoir-hose-ideas/
The 14.2mm hose should work nicely.
I hope so, my main concern is the tube kinking on sharp bends, particularly since the larger hose is a suction hose correct?
The 9/16 hose on its way to me should have a wall thickness of around 3mm or less, whereas the 5/8 tube I already have is 4mm.
Also I have a few 5/8 unicoils (http://www.unicoil.com.au/) which will work perfectly for bending the larger hose.
If the hose is available from Nissan, your dealer can get it.
Sounds like they're just being obtuse. Navigating the unfamiliar sections of FAST took my local dealer a while, but they were happy to help me.
Well my custom jobby turned out fairly neat. I put some 13mm I.D. PVC clear pipe over the fittings to give a firm seal with the 5/8 oil hose. Unicoils stop the hose from kinking, and I wrapped some old bike tyre inner tube around the whole thing, since the original ones had extra insulation too.
Still its a real close fit between the aircon fitting and the turbo inlet pipe. The original molded pipe has a sharp bend right out of the P/S inlet.
The smaller hose can use 3/8 hose, no modification needed.
