hey guys up for sale is my jzx90 genuine jz not converted lx90 like all others.
I have just completed a ground up build of the car everything is perfect and near new this thing is my pride and joy and will be sad to see it go but have to say good bye to it.
mods list
engine:
1jz 2.5l
new garret gt30/76r twin scroll with anti surge compressor housing v band rear
twin scroll high mount stainless manifold
turbo smart 44mm gate plumbed in with v band clamps so would be easy to convert to screamer if that's what you like
udsm supra cams
multi layer head gasket
all new gaskets
440cc supra injectors
sard fuel reg
all new water pump /timming belt /idler pulleys and tensioner
walbro fuel pump
greddy e manage ultimate ecu
front mount
hks exhaust
polished alloy centre cover
new engine mounts
e boost 2
am wide band
car also comes with a lap top with the tuning program on it
body
all fresh paint in r8 black metallic
pumped rear guards
rolled and pumped slightly fronts
full traum body kit
vertex very rare boot lip only one in oz
roof spoiler
shaved guard lights
trans is a built auto done by mv autos
1.5 valve body manualized
2800rpm stally
pwr trans cooler
suspension
hsd coil overs
cusco upper front control arms
adjustable front caster arms
all adjustable rear arms
trd lower triangle brace
cusco front and rear strut braces
brakes
slotted front rotors with endless brake pads
rears have
endless pads fitted as well
hels braided brake lines
interior
bride covered door trims
jzx100 seats
e boost 2
am wide band
carbon dash surround
clarion dvd player
and splits in front
all shitty wood grain is painted black metallic like the car
central locking and immobi
wheels
19 by 9.5 +12 front federal near new tyres
19 by 10.75 +12 rear achillies new rears
varsoen
wheels painted metallic silver
the car also comes with a heap of spares
standard front guards
standard bumpers
front lights
rear tail lights
trd diff bushes I have not had time to fit yet but will do soon when I get time or as part of sale
window switches
and trims
heaps of other small shit
top feed fuel rail so can go bigger injectors for more power
stock wheels
car makes 300kw atm at 18psi needs bigger injectors
car is also mod plated for the turbo in qld car is currently rego in nsw
also I have most of a manual conversion
trans tunnel
pedals
master
centre console
gear boot
gear box x member and mount
fly wheel
manual tail shaft
all you need is a box and clutch and you will be rocking a manual car
I only just finished the car and used it as a wedding car for my wedding now looking to sell to pay some bills this thing is my pride and joy
and will hate to see it go but I have to do it.
im looking at $16000 or best offer for cash
the worst I can say is no
the people who seen and go in the car love it I would be shocked if anyone looking to buy it wouldn't love it also
thanks for taking the time to read I have plenty of pics of the car if you would like more just pm me and will send them to you
cheers Bernard
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
