You are looking at spending 10k to have it pull hard..
You will spend a lot less if you get your stock turbo highflowed to the right profile, it will definitely give you the pull hard effect and will cost you a lot less.
I reckon a Hypergear G3.5 highflow will do a good job of the desired task, the delivery will give monster pull without being a pig to drive.
Before you ask, you will need a full 3" TBE, FMIC, fuel pump, injectors and an ECU at a minimum.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069538
It's not rocket surgery.
It's not brain science either.
GTScotT is offering some sound, experience based advice. He's also considering the driving outcome and financial aspect of things.
However if you are chasing a 500rwhp setup you won't likely get there with a GT30 setup. Go the GT35 and be mindful of people's comments to this point.
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069729
At the moment no one has given me a answer or opinion on what one would be more suitable
Yes they have...this:
and see also:
Look at the rb25 dyno results thread. It's not rocket surgery. People don't have to tell you what to do, you can figure it out yourself sometimes!
and forget the GT35
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069772
3076 56T with a .63 on E85 hits like a sledgehammer...
the hypergear stuff in same size are a more linear pull and deceptively quick, but probally faster no doubt
guess it depends what you after, i have no idea what a 3450 feels like on a rb25, only 25/30's and 30s's
guessing boost response would be fairly bad on a manual
cheers
darren
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7069900
Glad you put that 3 inch cooler piping, talk about overkill. You can make an easy 300kw on 2.25 inch piping.
Stop slapping parts on and read, there is so much information here you should be able to work out what you need, then see if you can go for a spin in a few members cars to get a feel for the response. I am guessing the GT35 will be a little too laggy if you plan to drive it daily.
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7070093
Read this thread - ultimate RB "pull hard" setup, make numbers in the range of GT35R peak power but spooling similar to the smaller GT30 range turbos:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
  • Like 1
https://www.sau.com.au/forums/topic/433565-gt35r-or-gt30r/#findComment-7073476
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
    • Legend mate, cheers for the response. I just got the block back from the machine shop and didn't wanna go drilling after I clean it.
