Hi,
How are you going? I'm good thanks. I am having difficulty with my alarm/immobilizer. It was on the car when i bought it and it is by far the worst alarm, probably on the market, disgustingly bad. The problem is as follows: i had the alarm activated and opened the door, the alarm starts going off, i go to push the deactivate button on the remote and it breaks off on the actual computer chip. I go to push the silent deactivation and the same thing happens, the button breaks off again. So i now can't turn off the alarm. I have managed to trace the wires to the alarm 'box' under the dash and found a reset button. I have tried holding it in, repeatedly pressing it with key in/out on acc position, doors closed open etc... all to no avail. If anyone could help / ideas that would be hugely appreciated.
Obviously the car won't start because of the immobilizer. It is a 32 GTR, and the alarm i have no idea. The box says 'SPY' so I'm assuming it's a spy 2 way led with remote start (not connected btw and the remote is a small mobile phone looking thing. A horrible cheap piece of f****ing s**tc**t, sorry for the outburst). I tried google-ing spy but can't really find anything and all i want to do is go for a drive but this stupid problem, from this stupid alarm is preventing it.
Cheers.
Hi Mate
I too have an R32 GTR and it came with a really shit alarm. Best I can recommend is to take it to a pro to safely remove the old/dead alarm and then secondly to fit a decent replacement. Bear in mind removing/fitting alarms isnt cheap cause its very time consuming due to the labor involved. You'll be looking at $600-800 to remove and fit an alarm and that doesn't include the alarm. Don't skimp on the alarm or the installation, this is the one thing that'll keep your car safe if setup properly - you don't want to buy an alarm and then not have it work due to a substandard install.
I can recommend Ministry of Bass (south/west of the city, not far from cbd) or GT Autosound (North/east), I've used both shops and they both have great prices and know their stuff.
-D
Always good to see a fellow GTR owner. Thanks for the advice, GT Autosound sounds the go. Happy to fork out for a decent setup, considering how easy they are to get into, just after one that doesn't lock the doors automatically, small in the pocket, at least 2 point immobiliser for my insurance and doesn't beep when the doors aren't locked ,if the windows down etc...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
