Clearing the garage up for space!
R32 Side Mount Intercooler $50
2008+ Standard CJ Lancer Springs $50
HKS EVC 4 with everything $250
R34 Dash Pieces, suits sedan/coupe $20 piece (Top condition, In blue will swap for black pieces)
Standard R34 Triple Gauge (Volt/Oil Temp/Boost) $60
s13/180sx Side mount Intercooler with all pipes (defect clearing) $100
CA18 Standard Turbo Manifold $50
Aqua One Fish Tank with everything needed for fresh water fish $40
Located Central Coast, Gosford, NSW
Willing to post items
I have photos but they're too big, can PM photos if wanted
https://www.sau.com.au/forums/topic/433577-small-garage-clean-out/
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
