Ok, so we all know HICAS shits itself easily if the steering wheel is non-standard with a non-HICAS boss, and when our steering wheels are not centred.
My car came from Japan with a Nardi wheel with an appropriate boss. I had no HICAS light illumination at all. I went to the trouble of removing the wheel and fitted a stock GTR wheel to my car (R32 GTR). Since then, after 10km of driving, the HICAS light illuminates. I put it down to the wheel being off centre, but I can't for the life of me see how I can get it any more centred than it is!
The other problem I have relates to the cancellation of turn signals. When my wheel points slightly to the right, I find it very hard to keep the indicator on - the cancellation block is obviously close to the switch, which is terribly annoying.
Today I decided to pull the wheel off and have a play around with the HICAS sensor located under the steering wheel, to see if it was perhaps off-centre.
A bit more background... with the Nardi wheel, the HICAS lugs sticking out of the steering angle sensor were sitting at the 12 o'clock and 6 o'clock positions; the factory wheel requires them to be in the 2 o'clock and 7 o'clock positions. Is this normal?
I took the sensor off to have a look at that, to see if it was perhaps 180 degrees out, but it appears not. I also took the back off the steering wheel to see what's inside... I thought that the lug slots were possibly sitting 180 degrees from where they should.
I've attached some pics to show all the details for those who can help, and for those who would like to see how a HICAS steering wheel works.
I'm dumbfounded as to the cause of my problem. Can anyone shed any light on the matter?
there isn't a boss as far as I know... isn't the boss built into the steering wheel itself as illustrated in the pics? What you see in the pics is what I've got.
Picture 1: horn button pulled out
Picture 2: wheel taken off
Picture 3: Indicator stalk cover removed
Picture 4: HICAS ring removed
Picture 5: Hicas ring attached by wiring loom, hanging down
Picture 6: Back of stock steering wheel
Picture 7: Back of steering wheel with rear coverplate removed, exposing what appears to be 2 magnets
Picture 8: Angled shot of magnets
no it is not. It is supposed to be sitting at 12 and 6 respectively.
I fitted my MOMO some time again with the appropriate boss kit and just yesterday, i replaced it back with the standard wheel because i'm selling my car. The lugs were sitting nicely @ 12 and 6 o'clock. I took it out for a drive and the hicas light stays off.
i think the problem is that you got your alignments off and mixed up because that they affect your hicas and indicators.
I guess the only wheel is by trial and error till you get the problem fixed.
When all's good, go for a 5 wheel alignment asap (including steering wheel).
hope that helps.
yup.... when i fitted my standard wheel back on .... the lugs were sitting at 12 and 6 respectively.... and the holes at the back of steering wheel were the same as well.
i think you might have to dismantle the steering wheel and get it to align properly again.
  • 2 months later...
I got the same problem and the holes on the steering wheel are 2 - 7 o'clock. Also, sometime my car would start pulling to the side once i hit 65 - 70 and the HICAS kicks in. It feels like drifting but without the wheel spin. The steering wheel has to be turned up to 2 o'clock to get the car to go straight. Once i slow down bellow 60 it fixes itself up.
Also, after about 10km the HICAS light would come on and then i guess the HICAS comp would shut itself off and the steering would straighten out.
Any ides anyone?
mine is like lindsey34's except i have the stock airbag wheel. light comes on after 10 minutes of fairly straight driving like on a highway or freeway only, and over about 70km/h. I have no performance issues with the alignment, indicators or hicas at all, just the stupid light.
  • 3 weeks later...
I also have this same problem. Perhaps its got something to do with the type of BOSS kit used? Maybe manufacture problems?
Genesis R: Was your BOSS kit a genuine MOMO item?
AFAIK my boss kit is NOT a momo item. Maybe a genuine will fix the problem?
My hicas sensors also sit at 2 and 7 o'clock respecitvely.
  • 3 weeks later...
my hicas light came on once the whole time i had a stock stearing wheel on, which was like 8 months, then since i have had my after market wheel on, about 4 months, the light has come on twice. its not a frequent thing, it has jsut literaly come on like once on the hwy after about 3 hrs of driving, and once before after like 20 mintues.
is it bad for the light to be on? like what does it actually mean? my wheel is actually off centre a little bit, but i got a hweel alignment so i asumed it would be ok to just leave it alone.
NRB my guess is that the alignment is offcentre (agreeing with genesis) with the indicator doing what it does. A good wheel alignment centre would be able to fix it for a price. Jack the car up and take a look at the tie rod ends and see if they have unequal lengths of thread exposed. If they are equal then the steering shaft has been pulled out of the steering rack and rotated to align the wheel which is pretty odd as the japs are usually pretty good getting this sort of thing right. If you wanted to come by sometime I'd be happy to take a look myself and might be able to fix it.
I can't believe so many people are having such problems with HICAS, but it is such a stupid idea.
Marcus, do the MOMO and get a Hicas bar. :rofl:
Geoff,
I'll have to get under and look. As you know I'm wanting to get one of your HICAS lock bars, but haven't heard from you since I sent an e-mail on 21 October.
Just to make sure I've read your reply correctly - check to see if it's EQUAL L/R, and if it is, it means the rack has been taken out? It should be UNEQUAL L/R?
And Mr AWDMAT, taking out the lamp doesn't help me when my steering wheel turns itself and straightens with a kick after 10km of driving now, does it? :confused:
Nick
sorry I never got that email, and I got others that day. PM's as well. Email me again and I'll happily supply one, but I'm more concerned with the number of failed HICAS and the symptoms and not everyone want or needs the lock bar. So even though I have a fair amount of experience with the causes and corrections, my intent is not to peddle the HICAS bars through others misfortune so I'll try to address the problems here as time permits ver the next day or 2.
Your steering is exhibiting the standard R32 response to the HICAS going into fault mode and then it changes the steering. Exactly why and how is not entirely clear but I feel it is the rear rack that defaults to a certain position and the steering caster then pulls the wheel over. Possibly due to the hydraulics and I don't recall this in the R33. The car will then be crabbing down the road and possibly handle crap. If the HICAS sensor in the steering wheel can be returned to the correct position then I believe it will stop the 7 km wheel shift symptom and return to standard operation as the HICAS senses the steering angle and the speed and then adjusts the rear wheels.
Look for the tie rod ends being unequal and maybe different steering lock on each side as this is not correct. If all is equal then the steering shaft has been turned.
Ok, as I stated above a have a problem with HICAS and it’s very similar as NRB’s. But there are a few very conflicting things about this problem.
1. Sometimes my car starts pulling to the left and I have to turn my steering wheel to the right to keep going straight. This happens as I go over 60 km/h and faster I go steering needs to be turned more to keep it straight – up to 10 o’clock.
2. Sometimes my car starts pulling to the right and I have to turn my steering wheel to the left to keep it straight. As above, it starts happening after I go above 60 and faster I go steering wheel needs to be turned more to correct it – up to 2 o’clock.
3. Sometimes my car just drives normal.
In all three cases the HICAS light will turn ON after approx 10 km. For the first two points, after the HICAS light turns on, the steering would start gradually correcting itself and after about 1 km it would be completely corrected and drive “normal”.
So far I haven’t been able to find what is causing the problem and I was never able to get into the HICAS diagnostics.
In cases where I NEED to make sure the car won’t start pulling to the side, for example when the car is on the dyno, I just unplug the HICAS computer. Then it works fine, but it does make the steering wheel a bit heavy.
The car is R32.
Any ideas?
NRB – does this sound like the problem you’re having?
skylinegeoff – “Look for the tie rod ends being unequal and maybe different steering lock on each side as this is not correct. If all is equal then the steering shaft has been turned.” - I think this wouldn’t be the cause as it’s inconsistent (pulling to the left, pulling to the right or just normal). Am I right?
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
