Hi all,
I have an R32 GTR and pulled the engine for a rebuild. While the gearbox was out I changed the fluids, Gearbox/Transfer Case and now the car is back together my speedo doesn't work. It worked before the engine rebuild and I originally thought cable so I got another one and tried it and it still didn't work. I know it's broken in the gearbox because I had the car on jack stands and running in first gear without the cable connected to the box and the little shaft that the cable goes into didn't turn. Have I missed something? I thought it would be purely mechanical looking at it so I doubt I've missed a plug or hose or anything.
Just wondering if anyone knows how hard this is to fix? I'm assuming it's a gearbox out job? Why would it have just suddenly broken? The gearbox works fine it drives no problems just no speedo which affects my powersteering. Have I done some damage when I put the tailshaft back in or something? Any ideas/answers would be much appreciated.
Cheers Brodie
Na man it's part of the cast housing right near the back of the trans. Not unless your talking about unbolting it from the inside of the gearbox but you def can't unbolt it from the outside.
Thanks for that. Yeah made sure they were located even had the cable attached to the gearbox and held the other end to see if it was spinning. Also got a drill onto the cable with it attached to the speedo. Got upto 120km ha ha. but its def in the transmission.
Hi Brodie, hopefully these pics will explain- the speedo drive does come out of the transfer case quite easily and without taking the box out of the car. I am assuming this is the part that will be broken The only thing to watch is the transfer case fluid will come out when you take the speedo drive out, so you'll need to catch it as well as top up your transfer case- easies way is through the gearshift hole.
Hey Andrew thanks for the pics but is there any reason why mine doesn't look like that? Are the push type different to the pull type? Or has someone modified my speedo drive or something? Mine looks like this
Hmm so as I'm posting that last post it occurred to me that could it be possible that my speedo drive has been pushed into the box too far ? Hence why mine doesn't look like Andrews?
Yeah I can see clearly now that that's what must have happened. The gearbox was sitting around twice for nearly a year each time so I guess I shouldn't be surprised. Any ideas on the best way to get it back out? Where does that drive cog on the end actually connect to inside the box? Will it help if I pull the Attessa line off the back on the transfer case?
Hopefully you've tried the above and been able to pull the speedo drive out already. If not, here's a couple more pics of what you're dealing with. I can't push the speedo drive into my transfer case as far in as yours is without risking damaging it, but if you take off the attessa actuator (don't remove the hydraulic line, and yes- transfer case fluid will come out) you should be able to use a screw driver or similar to lever it out. I've taken some snaps of an empty transfer case with the speedo drive pushed right in so you can see what it will look like inside m(and i was able to lever it out with a screwdriver through the attessa actuator hole). You might need to rotate the inner sleeve of the drive as you go so the teeth line up with the worm gears on the driveshaft as it comes back into contact (yours will have actually been pushed passed the point of contact).
Make sense much? Hope that's helpful.
Hey Andrew yeah that all makes sense thanks heaps for doing that. I'll try pulling it out tonight but I'm guessing I'll need to remove the actuator and do like you've suggested so I don't risk doing any further damage to anything in there.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
