I was wondering if you guys could help.I have searched the net and not had any luck.
Basically i have an automatic R33 Spec 2 which needs a new rad,i was told a stagea rb25det one was the same and i found one of an RS4 the owner said it was an automatic and he was stripping it for parts to sell,so i had the radiator .The rad arrived today and looks to me to be the same as an manual one. As apart from the two pipes top and bottom on the rad and a sensor from next to the pipes there is nothing else ?would there be more if it was an automatic rad.?I was told that you could use a manual one and pipe up a seperte cooler for the trans, and i have found one next to the horn is this for that purpose and where is that piped to and where would you pipe a sperate one into a manual rad.I am very confused by it all ,and i am sure i am prob making you the same way.
https://www.sau.com.au/forums/topic/433636-trans-etc-help-please/
You can run an external trans cooler instead, but then the box will take ages to warm up, which is the main reason they are placed in the radiator in the first place.
I would be selling that radiator and buying an auto one with the cooler in the bottom, then run an external cooler before the radiator cooler.
how can you tell the difference between the manual and automatic radiators please.If i do manage to get an automatic one do i need to run a external cooler as would it not run to the setup which is on stock atm?Also is that same rad next to the horn for the power steering sorry for all the questions.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
