hi all
in my previous post I had a question about the nm35 stage engine vq25det.
the quality and style of these cars is a big bonus as is the power from the engine.
however due to really liking manuals and the ease of modifying the rb25det neo 6 engine.
I have decided to buy a 25t RS Four.
modifications planned once I have vehicle are as follows.
Link G4 plug in ecu ---- everything I have read suggests they plug straight into s2 stagea
Upgraded turbo ---- unsure on what specific one yet.
Electronic boost controller
Inlet air temp sensor
upgraded turbo back exhaust
Return Flow FMIC
AFM delete pipe
the Link G4 ecu comes built in with a MAP sensor so I want to go down that track of getting rid of the AFM
at this stage I wont be after too much power future modifications if I get the itch for more power ill add a front facing plenum change intercooler and upgrade injectors and exhaust/turbo manifold
hope it all goes to plan with no hickups and I will be posting pics I tend to go snap happy
Edited by stripey
https://www.sau.com.au/forums/topic/433648-ive-decided-on-a-stag/
There are hi-flow rebuild options for the standard turbo which should give you enough headroom for a while.
If youre going to start from a stock car, then theres probably a lot of groundwork maintenance to be done in the suspension for example.
work at pedders so shouldn't be too hard or costly to sort suspension out
Hi Jarrod & welcome. Why not buy a clean 260RS straight up & be done with it? For a while at least. :yes:
Cheers GW
I agree, little disappointed I didn't go down this route and settled for a rsfour, when really I should have waited and bought the right car the first time. Now don't get me wrong I love my car but sometimes which I had the manual option.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
