Rb26dett engine from a r33 Gtr vspec, motor has done approximently 10,000kms since build. I have pictures of recent cold/dry compression test and can send or show to serious buyers only.
**Can fit and install for extra by mechanic locally on the Gold Coast pm for details**
Compression 160-165psi across the board
Bottom end
R33 Gtr crank
Genuine N1 block (24U)
20 Thou Cp pistons and rings
Eagle rods with arp rod bolts
Arp mains
Arp head studs
Greddy oil pump
N1 water pump
Tomei oil restrictor
ATI Harmonic balancer
Gates timing belt, tensioner and pulley all replaced in build.
Engine has been rebuilt, blueprinted, machined for 20 thou pistons and rotating assembly balanced. Block had been decked with all new welsh plugs.
Top end
Tomei Poncams 260deg 9.15 lift in and ex
Greddy cam gears
Timing Cover has been polished
1.2mm Tomei metal head gasket
Brand new rocker cover seals and half moon seals
Painted r34 Gtr red covers and plenum
Head has had a full recondition with all new retainers replaced on both sides, valve regrind and lifters serviced.
Engine comes complete with intake plenum, manifolds, all new hoses, r33 gtr sump, turbo oil/water lines, engine mounts, alternator and AC pulley and bracket. No injectors or rail or turbos, however can source parts and install on request.
Engine has been comprehensively inspected by a qualified mechanic, leak down tested, cooling system tested and compression tested, since removal. Has also been tested and run, is in perfect operating condition. Has been built for and used in a 300kw setup for drag purposes, perfect for track or street setup.
Price $8500
Located Gold Coast can Freight Anywhere Aus wide
PM or Call/Msg 0414596256
Edited by toy515
https://www.sau.com.au/forums/topic/433665-built-for-high-hp-rb26dett-for-sale/
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
