Up for sale is a standard RB26Dett which has done approximately 20,000 kms since rebuild. Rebuilt with standard internals, new nissan rings and acl bearings, with a bore and hone of the block. Rotating assembly has been balanced with an aftermarket balancer fitted. Has a metal head gasket and a full head reco on rebuild with a overheat tab on the rear welsh plug. Currently the motor has a r32 gtr sump with the diff cut and shut off for a RWD application. All hoses are in very good condition and motor comes with intake plenum and an alternator and power steering pump with hicas part removed.
Engine was removed from an R33 GTST and comes as pictured without any hot side (turbos etc) or injectors or rail.
Has been compression tested and inspected by a qualified mechanic. Compression 155psi across the board.
Price $2500
PM or Call/msg 0414596256
Located Gold Coast willing to freight Aus wide.
post-50709-0-68780700-1382271104_thumb.jpgpost-50709-0-79889100-1382271157_thumb.jpgpost-50709-0-31076000-1382271176_thumb.jpgpost-50709-0-27597500-1382271196_thumb.jpgpost-50709-0-90940400-1382271216_thumb.jpg
Edited by toy515
https://www.sau.com.au/forums/topic/433666-rb26dett-standard-freshly-rebuilt/
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
