Performance Parts Sale Gt35R Turbo Kit, A.r.e Galore, Sard Injectors, Superspark, Bosch, Walbro + More
Rb26 turbo kit
Genuine Gt3582r
Stainless manifold
Tial 60mm wastegate and screamer
Dump pipe and intake pipe
Comes with all oil water lines fittings etc
$1500
Sard 800cc injectors with sard fuel reg on a rb26 fuel rail
$490
Superspark coilpacks suit rb20 rb26 rb25 s1
$260
A.R.E radiator set up for r33 gtst comes with thermo fan, the bottles and hoses etc
Best set up I've seen for a long time
$230
A.R.E r33 washer bottle
$60
A.R.E power steering reservoir
$50
Greddy Intercooler kit comes with everything
Removed from r33 but will fit 32 34
$200
R32 vented fibreglass guards imported from Japan fitted and painted orange
$150
R33 Gtr fuel pump cradle fitted with Bosch 044 pump
$140
S15 fuel pump cradle fitted with walbro pump
$120
S15 aftermarket taillights
$70
R34 r33 high mount dump and front pipe v band
$40
Cusco coilovers pretty sure they are for forester
$100
R33 gtst stainless catback exhaust
$100
R33 hicas lock bar
$40
Turbo timers blitz greddy etc
$30
Located on the Gold Coast but can post
post-50709-0-07871600-1382300029_thumb.jpgpost-50709-0-46343200-1382300047_thumb.jpgpost-50709-0-54736000-1382300067_thumb.jpgpost-50709-0-91963500-1382300126_thumb.jpgpost-50709-0-59990300-1382300151_thumb.jpgpost-50709-0-91612600-1382300205_thumb.jpgpost-50709-0-90757500-1382300254_thumb.jpgpost-50709-0-84012500-1382300286_thumb.jpgpost-50709-0-54388900-1382300484_thumb.jpg
Is the Turbo manifold to suit RB25 or RB26?
I thought the exhaust stud pattern was different?
It it will fit a RB26 I am very interested.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
